1 - 20 of 30 Posts
Hi all, I ride an R1200RT (in the UK) with its wonderful electric screen. Up in the winter and down in the summer. I have bought a 2015 650LT for a trip in the USA and was wondering if the gen 3 stock screen is ok for warm/hot weather?
I have never been on a bike with an air temperature much over about 27 degrees C (80F) and I have been told that temperatures in July/August in the Texas/Arizona areas get a LOT hotter! I am guessing that a bit of a cooling breeze will be invaluable in those temperatures so maybe a bigger aftermarket screen would be a bad idea?
On the other hand, I will be riding fair distances and maybe reducing buffet may be a priority?
It is a bit tricky as I will riding north (Alaska) and it will get much cooler....also my UK riding gear is designed for the British weather - maybe a complete new outfit is required.... more money, limited space, groan.....
I suppose I am asking "what is it like riding in very hot temperatures and what can I do to make it as comfy as possible?"
Any advice from those that ride a 650 versys in hot climates will be most welcome!
John
I just bought a lighter weight vented jacket by Fly that should work good for hot temps. I live in Texas. I also have a "cool" vest that can be used under the jacket that should be nice. Drink lots of water and take frequent breaks.
You'll need some wind protection because of bugs, flying debris, and dust. I'd just leave the stock windshield on, because, as far as I'm concerned, it doesn't provide enough protection to comfortably ride the V in the rain. So I imagine it'll be just perfect for hot weather!
I ride in the Olympia X-Moto jacket (v1, high viz) The V2 is reviewed here https://www.revzilla.com/motorcycle/olympia-x-moto-2-jacket Watch the video to see the massive vents that are great in hot weather.
I ride with a t-shirt and liners down to 2C / 35F and just the jacket to 40+C / 105F.
The latest version comes with a 2 litre water back (twice my 1 litre) and a rain jacket you can use under or over the main jacket.
Other than being a bit grubby from riding to Alaska last year, it is still in great shape.
I haven't had any zips, etc, fail.
Thanks guys, I will get a chance to try it out next week so I shall be better informed regarding what needs to be done.
I changed out to a bigger screen (in its lowest setting is like stock in it's highest). We haven't had any 95+ (35 c) days yet since my upgrade here in South Central Texas but I imagine it will be fine (being a native and all). I really wanted to protect myself a little better from bugs. With that said the stock screen wasn't bad but at 6'3" (190 cm) the wind over the screen was hitting me smack in the visor.
To keep cool I have a mesh jacket, hydration pack that I fill with ice water, when ever I come to river I dunk my under shirt, and if there is no river I will blow air into my hydration pack then flex my shoulder while I hold the mouth piece open and spray my neck and chest with water :p.
Hmmm... that sounds like it is seriously hot! I shall investigate whatever a "hydration pack" is!
Regarding the screen - I am 5 feet 9 in so I am hoping the stock screen will be ok for summer use.
Stop living in the past and get an adjustable windshield like a "Madstad" one.
It's tall, short, tilted, upright.. and all in between.
It's what you want when you want.
I want it as high as my chin, to beat the morning fog in some area yet see over it, not through it.
I want it as low and tucked as possible when riding in trails and hot temps.
I get it all.
Best expense ever.
No I don't work for them.
I'd like a screen that is wider AND higher. Which would you all suggest? I have the 650.
I get it all.
Best expense ever.
Is it electric like the RT or Pan (ST1300) ones?
What is the general route of your planned trip? We might be able to help you avoid the areas with the worst temperatures.
I have ridden through many of the states in the US, especially in the west where I've travelled multiple times over the last 20 years (see my sig below). Almost all of my transcontinental travel (all done on Honda ST1100s & 1300s) took place in July, August and September. On some trips I experienced temps as high as 110 degrees. I can tell you from my experience with those rides that you need to have a strategy for dealing with the heat. A core principle of this strategy is to stay hydrated. The kind of bike you ride does not matter. The principles are the same no matter the bike.
One of the best articles I've ever read on the subject of long distance (LD) riding in high temps is this article from the Iron Butt Association (IBA). I would recommend reading it before planning your trip because these guys know from experience what they are talking about:
http://www.ironbutt.com/ibmagazine/ironbutt_1002_62-66_Hot.pdf
Here's a quick video that shows the route (in 2011) of the every other year, Iron Butt Rally, held during the summer. It runs for 11 days and the riders cover 11,000+ miles. As you can see, during this rally, they rode in areas that were pretty hot that time of year. These guys had to have a way of dealing with the heat or they would never have been able to compete:
My LD strategy to deal with the heat can be summarized as follows:
1. Hydration - stay hydrated! Either stop often or have some sort of hydration system on board that allows drink while riding. These systems are commercially available (camelback, etc), or you can make your own like I did.
The picture below shows what I made mounted on the bike. It's a small cooler that I stuck inside a tail bag. You can see the drinking tube. This picture was taken during an August/September trip in 2009. I experienced temperatures as high as 108F so this device was a godsend.
2. Riding Gear
a. Do not use mesh riding gear if you are going to be riding in temps above the mid 90's (see IBA article above). Leave the mesh at home.
b. Wear light colored gear. The darker the color, the more heat it absorbs and thus the hotter it gets. An article I saw 15+- years ago in Motorcycle Consumer News showed that color dramatically affects heat retention. The difference in temperature between a black jacket and a hi-viz yellow jacket was as much as 17 degrees F!
3. Food - eat light meals low in fats. A big meal, especially one high in fat, will make you seriously groggy and even put you to sleep if riding long distances. This effect is amplified if riding in hot weather due to the fatiguing effect of high temps.
4. Rest - take micro naps when you get the chance. Many of our highways have rest stops that have shaded picnic tables (aka Iron Butt Motels) perfect for stretching out on for a short snooze. I've even napped on the bike with it on the center stand in these shady spots. There's nothing like a 5 or 10 minute nap to perk you right up and allow you to continue on your journey more alert. These naps are especially useful in high heat because of the fatigue that high temps induce.
And finally....
Hope you enjoy your trip. Just do a little prep work prior to starting and you'll have a great time and witness some of the incredible eye-candy that our country has to offer, such as that in this picture from one of my trips through southeastern Utah:
Discussion Starter #14
Superb information... thankyou so much for taking the time to share. Looks like 93 degrees is the magic temp for comfy riding!
Great advice ref underwear etc... really appreciated, as high temps are never an issue in the UK
... high temps are never an issue in the UK
An understatement. I was stationed at an RAF base in the Midlands from 1971 to 1973. The year I left it got up to 85 degrees in London and people were fainting in the streets! Heck, at 85 we're just getting comfortable in Texas... :).
As noted above, the Olympia X Moto 2 Jacket comes in Hi-Viz, has lots of ventilation and has a 2 litre hydration pack as part of its setup
Discussion Starter #17
My wife is beginning to think I am having an affair... too much time scouring the t'interweb and buying stuff from eBay! Looks like buying the bike was just the start! You guys are killing my bank account.
I have just looked at temps in Alaska at that time of year - I will need kit for all seasons! I feel a trailer coming on.... :(
Wolfcamp - where were you stationed? I was in the RAF around that time.
John
I was stationed at an F-111 base, RAF Upper Heyford. From what I've heard, it closed in the early 90's.
Heyford was a great place to be stationed. Beautiful countryside and easy access to the Cotswolds and Wales. London was just a train ride away from nearby Bicester.
Discussion Starter #19
Yes, it closed in 94...
"The runways are now home to a variety of wildlife including the scarce Lowland Calcareous Grassland and rare bird species such as the peregrine falcon, skylark and buzzard. Some of the buildings are used as an automotive storage compound for new and used vehicles. Other functions include police driving activities such as training. "... shame as I always loved the F111 - you guys certainly know how to build aircraft! I was flying a Hawk at the time at RAF Valley (North Wales) - happy days..
If you can figure a way to mount it, you're welcome to my home made hydration setup. The ravages of old age and the medical issues that sometime accompany it have left me unable to do transcontinental travel any more, so I no longer need it. Since I'm in Houston where your bike is, you could swing by and pick it up prior to departure.
EDIT: Just checked and I don't believe my setup will work on the Versys. The cooler needs a flat surface to sit on and the passenger seat on my LT is slightly rounded! No bueno.
One last tip. When traveling in the American west during the summer, one thing that many people don't know to check on prior to departing is wildfires. I learned about this the hard way. Some years it seems like the entire western US is on fire! Smoke from these fires can really screw up the scenery. Below is a great site to use in the planning stage to avoid wildfire areas:
https://www.geomac.gov/viewer/viewer.shtml
1 - 20 of 30 Posts
