Since it's suppose to get to 87 degrees today i wanted to get the filter changed this morning.
K&N Air Filter Install by weljo2001, on Flickr
Took the 2 upper side fairing off and the 2 tank bolts. Only needed to take one hose off on the left side of the tank right by the grommet that you can see in the photo.Pulling the tank straight up the bar risers will be in the way so just move the tank while lifting to the right or left to get by the risers. When i lifted the tank i found a bolt that other have found while working on their bikes
Used a handle off a paint roller to hold up the tank.
Took all the screws out of the air box. Would hold the tank when needed to get to the bottom screws.The stock filter has the screen to the top..Had 7200 miles on the stock filter..
K&N installed and air box tightened down with sticker put on. The screw in the middle of the box was a pain so i took one of those telescoping rod with a magnet on the end put the magnet end to the screw driver rod next to the handle and it allowed the screw to stick to the screw driver so i could guide it into the hole and tightened it down.
Lowered the tank to it's position and tightened the tank bolts. Needed to use the telescoping magnet again to get the tank bolts lined up in the holes. Put the hose back on the tank and put some multi purpose white grease on the grommets to make for an easier install of the upper side fairings (worked really nice)
