Hi there - I'll post this again in technical when I get my privileges but figured I might as well make a real post.
I started the bike up today and went to lunch, no issues. When trying to return, my ignition switch turned the bike off when trying to start it up. As in - I turn the key, the neutral light comes on as well as the LED (2012 Versys), but when I hit the ignition, everything turns off without even trying to start the engine.
Left it alone for about 10 minutes and it started up just fine. It's started up fine every time back at my house too, I can't replicate the issue. But I wonder if anybody knows what it might be so that I don't get stuck somewhere if it happens again.
+1 on checking the bat
While you're at it, remove the bolt and clean off any oxidation on top of battery termimal and underneath connector with fine sandpaper or some scrubbing pad.
