1 - 14 of 14 Posts
Hey all.
I just bought a 2008 Versys 650, almost 38,000 KM on it. I was told the chain and sprocket was replaced last year, but I don't actually know how many miles are on it, or if that is even true.
It looks like the chain/sprocket could go for a good cleaning, but I don't actually know what to look for when deciding if its time to replace the rear sprocket, besides bent, missing or broken teeth.
Here's a couple pictures.
https://drive.google.com/folderview?id=0Bz-3HOeFn-u2QjNyWmlUTlR3d0E&usp=sharing
I agree w/ onewizard.
Here's a pic of a rear sprocket at aprox. 56,000 miles, against a new one. Note that the 'tips' of the teeth (as shown on your pics) are NOT visible here, on the used one. The chain had worn the sprocket DOWN so it was lower.
Thanks Guys!
I'll get a picture of the front sprocket when I get back home (traveling for work), although I don't know if the front sprocket was ever changed.
Planning on doing my first chain cleaning/maintenance here in a couple weeks, just need to buy the tools/lube/grease.
The front sprocket wears at twice the rate of the rear due to fewer teeth and thus more loading on each tooth
Sent from my VS985 4G using Tapatalk
Thanks Guys!
I'd suggest you order/ buy another front sprocket (the ones w/out the rubber damper are just as good...), and have it on hand to replace WHEN it becomes necessary. The nut holding it ON can be a 'bear' to remove - check for threads on removing it.
Thanks for the advice.
Haven't had a chance to take a look at the front sprocket yet. Makes sense it would wear faster.
Should I look for straight OEM replacements or are there any preferred/suggested aftermarket parts I should be looking at?
Should I look for straight OEM replacements or are there any preferred/suggested aftermarket parts I should be looking at?...
I use SunStar ones (and I BELIEVE they also make the OEM rubber-damped ones) or JT (w/ a "half sun" logo) sprockets.
I believe the rear sprocket is sunstar already, not sure about the front. I really need to take the time and pull that plastic cover off and check.
Of course it's my anniversary today, and the wife seems to have the evening and a weekend trip planned. Might have to wait till next week before I can check or get the bike out for some fun.
so, about sprocket teeth...
I am due for a change (I think) of the front and rear... just want to make sure of the number of teeth - front is 15t, rear is 46t and the chain is 520 - 114 links?
That is correct if you want to use the stock gearing. If you want to change the gearing, this is the perfect time for it.
front sprocket bolt size???
I am about to change the chain, front and rear sprockets. Can someone who has changed their front sprocket tell me what size "mm" I need to remove it and how much torque should be applied in the re-install? I know what I need for the rear as I have removed the rear wheel before.
Thanks in advance.
Thanks in advance.
You need a 27mm or 1 1/16 socket. Use a 6 point socket, the nut can be very tight and you might round the nut with a 12 point socket.
Thanks in advance.
27mm or 1 1/16", 6-point as already posted. Just checked my 2015 SERVICE MANUAL - torque is 122'/#, but I THINK the SERVICE MANUAL for my Gen 1 says 92'/#, and as it's in AZ - can't verify....
1 - 14 of 14 Posts
