How often do you change your engine oil/filter?
  • Total voters
    40
1 - 16 of 16 Posts
How often do you change your oil/filter?
Regardless of how many miles you put on it during the riding season?
On the Versys oil every 3000 miles or so. Oil Filter Never........
Was changing every 3,000 using Mobil 1 4t. My mechanic was like hey man give that oil instead throwing out I will put in my bike for another 5. lol
So now I am going 5,000 between changes, Editing because I re-read some of the post, and relized that I will change it out every season even if I do not get 5,000 on the odometer.
I liked Invader's answer. Thats more my style even though I have changed the oil without changing the filter mid-season I am probably accomplishing nothing but consuming 1.7L of oil. That is not a bad downside actually.
I checked 3000 miles, but I'm comfortable letting it go till about 5000 miles, since I use synthetic. I change the filter with every oil change.
And, before you ask, coolant gets flushed/changed every other year!:) With silicate-free stuff. I usually just get the motorcycle premix stuff.
I change both at either 5,000 miles or at 8,000 kms. My "reminder" is the odometer: in AZ if the 'thousands' end in either '5' or '0' it's time to change (ie= 25,000 or 30,000); and in BC if the 'thousands' end in something divisible by '8' (ie= 40,000 or 48,000, etc) it's time to change.
That way I don't need to look for my records of WHEN I last did it. (Learned this from one of my "hot rod" chums.)
:goodidea:
Twice a year.
Drain and refill in fall.
New Filter and drain and refill in Spring.
Or vice versa.
1 - 16 of 16 Posts
