Because one of my OEM bar ends broke. The rubber inside it came apart from the metal wall so I used them to add mass to my mirrors to reduce the vibration. Works great, 50-60% improvement but they look crazy.
Less bar ends I toyed around with various ways to devise a simple friction device (just for fun). Won't use it often since I spend more time doing stuff like this than riding and I hardly do any distance on this bike. Works really well, allows easy throttle downs even when engaged just like the $100 ones, just not as easy to deploy since you have to tighten the compression bolt which is the opposite direction of a throttle action.
It's crafted from 4 little pieces. The large rubber gromet has a plastic cap inside of it. The plastic cap covers the bar end insert protrusion and has a hole in it. The key is the smooth round metal ring that sits against the throttle grip. The compression bolt that holds everything together is from an adjustable office chair I took apart 6 years ago.
It's simple, looks pretty decent and it only took 10 minutes to do although finding all the right size components took a few days (sifted through a lot of junk). The best part is, I made it myself and it works just fine for what I need it to do. Would I use something like this on my C14, no but that's why I like the Versys - it adobts well to almost anything we throw at it and it still retains good purpose and style.
Love this bike!!
sometimes it nice to exercise your imagination even though it can be bought cheaper
once again it's your toy and only you have to be happy with it
tinker on
I was expecting to see wires and circuits and actuators. So do you put a rock on you gas pedal and call that cruise control? LOL! We used to get throttle locks in the 80s for a couple bucks.
LOL!! You're funny!! :clap: - Btw, in case you didn't know, for most folks in the USA a Versys is a relatively inexpensive bike so not sure why anyone would go the wires,circuits, actuators route. When you can spare a bit more cash buy a high end BMW, the one I had with an electronic cruise control system failed and was repaired twice. Give me a rock any day mate - LOL!!
Throttle locks worked OK when I lived in flat Florida. But here in the hills they are only good for a momentary break for the right hand. Electronic cruise can be added for a couple bills.
A friction lock works well to hold the throttle while ya wring out that right wrist.
Larger displacement motors work better, but any friction lock is better than no friction lock.
