1 - 13 of 13 Posts
Does anyone have an idea on how to dim the high beam indicator? When I use high beam, it practically blinds me. Oh it is a 2015 650.
And no tape over the bulb :smile2:
You could open the gauge cluster and replace the high beam LED for a dimmer one... Some have also replaced LED's to change the backlit color.
I also vote NO for tape that will mess up the display's clear plastic.
if you are worried about the glue affecting the clear plastic....
Ok... try Post-It Flags
Post-it® Brand Products:*Flags
its sticks and is not glue
I work in an office and use these flagies over and over again - still usable even after 7 years stuck to paper!
They don't leave residue.
cut up the sticky part to cover the led
get some 3m Magic Scotch Tape - it's opaque. stick a couple of layers over the light. It will soften it.
There's paint made to spray on windows to darken them. You could always try that, either w/ a brush, or by 'masking' the rest of the dash and then 'rattle-can' it....
You must have photosensitive eyes. Just put electrical tape with slits cut in it, then you can vary it to your liking.
1 - 13 of 13 Posts
