1 - 19 of 19 Posts
I just sold my Suzuki DR125 and am looking at buying either a 2009 or 2010 Versys 650. I have found one of each for sale and they are both about the same price / mileage.
Read up on the changes for the 2010 line (headlight, rubber engine mount and other stuff).
Can I get opinions on which one would be the better way to go?
Thanks!
Need More Info
Thanks!
To give a educated answer I would need to know the mileage , that has a larger bearing than the year. The rubber mount on the engine isn't a big factor, I had a 07 Versys , now a 2015 650 ABS, the ABS is significant, the difference between the 07 and 2015 as to engine vibration, not noticeable to me .
The mileage is directly related to the bike maintenance, several things need attention for either bike, brake fluid change, condition of fork seals, tire condition, charging system, all of these I would class as something to pay attention to and if they have been done or checked within the last 2 years fine, the last charging system can be very expensive if updating to OEM , around $500 for the stator, better and cheaper ways to go if you follow my advice. What is significant is the valve shim check which is also directly related to vacuum sync, this can not only be very expensive, if ignored can be the root cause of engine failure. Many have found tight valves at half the recommended mileage, my 2015 I did at 11000 KM , one tight exhaust valve, my 07 I did at roughly 30,000 KM , 2 tight exhaust valves and one intake valve out of spec.. The 2010 they started with pre-wiring a auxiliary outlet and a auxiliary fused / switched circuit. So the choice is yours, dependent on more information and photos.
Thanks for the responses! They both have about 16,000 miles on them.
The tires looked good.
I'll look at the fork seals, but what am I looking for? Leaks?
The valve stuff, I don't have a clue on that.
What's an easy way to check the charging system? Just put a multimeter on the battery posts and look for 14.4 v or something like that?
One of them does have a Yoshimura pipe and crash bars around the engine. The other is stock but has been lowered one inch.
personally i love my 08 (same as 09) when i first saw pics of it i thought the front was kinda off looking but in person fell in love with it, and still loving it at 40k miles on the clock
I am not sure how the vibration is on 2010+ and 2015+ bikes, the 1st gen Versys does vibrate a fair bit and will make your hands go numb after 45-60 minutes.
It's a done deal, sitting in the garage!!
Green 2009 Versys with 16,000 miles. $2690 USD.
Has the Yoshimura pipe, and SW Motech crash bars.
It also has some Pannier looking bars on the back with a sticker that says SW Motech. There were a couple of Rigid brand hard cases attached to it, like Pelican cases. LOL, looked like I was going to Home Depot. I took those off already. They were not quick disconnect but were bolted on with steel bar plates. I'll have to see what cases are designed to attach to it.
It has a seat that says Seat Concepts, some sticker thing on the gas tank thats says ProGrip, and what looks like an aftermarket gear indicator by Gear 8 Idea. Tires are Michelin Pilot Power 2CT with plenty of tread.
Could someone do me a favor and send a PM to user Ndv21 to contact me:
I'd like to buy the lowering kit he has in the classifieds but system won't let me send messages as I'm too new.
For Sale
NOTE at about 8PM today you should be able to send PM. Also note there are several for sale adds with additional farkles available for the 2009, you need to view the whole add. Highway pegs and lowering pegs, both I wouldn't be without!!
I have a lowering link for sale and also a rear hugger which will work with it. I can post pics using my email. [email protected]
Thanks, Mark
Discussion Starter #13
Thanks! I feel like a dunce, but after looking at the moto today I discovered that it already has the Moto Werk lowering kit installed.
As long as I'm in dunce mode, can someone tell me what these 2 black bars are for? They were in one of the Home Depot pannier cases I got. And also, can anyone ID the windscreen on my bike...is is stock or does it look like an aftermarket?
Going to change the oil and filter this weekend, then adjust the chain as it has a little too much slack. Everything else looks good! Probably change the spark plugs, air filter, and brake fluid in the next month or two.
im not sure but i think they might be someones maybe homemade side case mounts? (try holding them up to the bike and see if that bracket patches up with the pillion handles)
also i find your windshield quite interesting. thats two of the factory screens bolted together upside down
I see the LOWER one as reversed, then another added on top, right-way up.
Discussion Starter #17
That is hilarious! I wonder why they decided to do that. Think I'll take one off and mount it correctly and see how I like it.
Just got the oil changed and am going to tighten up the chain as soon as I finish reading about the steps.
Hopefully tomorrow I'll get a little riding in!
most of us 1st geners found the stock windshield works best mounted upside down (if you are of the taller nature) that is the first time ive seen two stock ones put together like that. and as for your chain, just remember that a tight kills the chain, sprockets, bearings, and other internal components. so make sure you dont over tighten your chain and also check your slack im multiple places on it (chain almost never wear perfectly evenly)
Discussion Starter #19
Ok, thanks to everyone for welcoming me. Here is my final post on this thread and I'll move to the regular forum boards for any further questions.
End of week wrapup:
Super pleased with my acquisition. Was not familiar with the Versys model before I saw it and I liked it instantly. (had a Ninja 600 back in 1987 for a few years) So glad I went with this one as it had many aftermarket options already installed.
Changed the oil and filter, adjusted the slack in the chain and cleaned and lubed it. Trickle charged the battery. Washed it. Rode it! Picked up the rear wheel stand from H freight. Everyone freaks out when I tell them its a 2009, it looks brand new!
See you on the road....
1 - 19 of 19 Posts
