1 - 2 of 2 Posts
Jay - you probably need to PULL that cable-end in your pic about another 1/4", so that the cable goes thru the "notch".
IF you still can't seem to do it - loosen that bolt just on the right of "Pic 2" - holding down the cable - pull out the 1/4", slide it IN, then replace that bolt. SHOULD work for you.
1 - 2 of 2 Posts
