1 - 15 of 15 Posts
...around 25 percent of motorcyclists wear the wrong size helmet. The survey also revealed that around 20 percent of riders said their helmet almost came off in a crash.
https://www.visordown.com/news/product-news/survey-lifts-lid-poorly-fitting-helmets
That surprises me a bit that it's that high. I was super paranoid / careful to ensure a proper fit. I probably tried on 30+ helmets before I found a few brands / models that fit. If I'm going to spend serious coin on a lid, darn straight it gonna fit right. But I guess there's always those that walk in and buy something based on the graphics without knowing or caring.
Agree
In my younger days, fit really didn't matter much as it was more about looks.
But after experiencing a 55 mph end over end on a bike my thoughts soon changed. Certifications and proper fit some how seemed more important!
Sent from my SM-G950U using Tapatalk
Quality does matter for head protection. Got a Carberg Sintesi Helmet direct from factory in replacement under warranty for some minor defect, which I raised to the factory.
Fits well and ventilation is good, only problem is when its come to noise level, a bit high for comfort...
Huh, never heard of Caberg helmets. Had to go look them up, Italian, very race-centric design. Are they DOT or just ECE? Oh, wait, I see you're not in the US.
My problem with helmets is finding the right shape, not the right size. I'll bet that is what happens with most so they end up buying too big in order for it to not create pressure points.
My last couple helmets required ordering miss matched internal padding. One is XL for the crown padding and L for the cheek padding on a helmet described as intermediate oval. Another is the opposite for a helmet described as long oval.
My hair cut makes a huge difference as well. My summer cut and my winter hair are almost a full size difference in the helmet.
It is hard to tell which helmet is going to be comfortable until you go for a 2 hour ride with it.
...My hair cut makes a huge difference as well. My summer cut and my winter hair are almost a full size difference in the helmet....
WAIT till you're 'old' - hardly any difference whether I just had a hair-cut or not....>:)
That is what I went through, finding the right shape. I know I'll probably never own an Arai or Shoei helmet as they tend to run in the ovals and I need something more round. Darned near ripped my ears off a couple time. Of course that would make it easier to take on an off:surprise:
Huh, I'll have to look into different size internals to customize the fit better but it fits pretty good right now, never thought about doing that.
I've found that many helmets feel nice when trying them on, but they quickly loosen with use. My head is very average shape and size. The right size feels a bit tight when trying it on in the store.
and when trying them on you have to literally try to pry it off your head to see how much movement it has.
I know it works well if the shell size is the same for the two sizes you are mixing internal padding on. Not sure how much the internals are different for the different shell sizes. Most helmets only have two or three shell sizes to accommodate small to XXL.
That number is probably so high because people buy helmets on the Internet now instead of locally where they can try them on. When buying on the Internet, they guess on the size, then figure "it's good enough" because they don't want to hassle with a return, or can't return.
I always pack a skull cap if it gets cold so I need my helmut a little loose. Theres a lot of mountain passes here in the N.W. and you never know when you may need it! A cold brain doesnt function well...
I agree about buying a helmet local so you can try it on. When I was ready to get back to riding I stopped at a Honda shop and they had an HJC full face in 3XL. I put it on and asked the guy if this was the right fit. He grabbed the chin of it and yanked it to one side. My head came with it and he said "it fits just right". After three ibuprofen for the neckache and I agreed with him. I also agree with trading locally, but some times there is no spot that has what you need, especially in oddball sizes. So I have stuck with HJC and ordered what I needed if not available local. That said, I have to give kudos to Revzilla for showing each helmet and which SHAPE head it fits. Also Mr Fast Talker mentions that in every review. I agree, a little snug to start (the first 5-10 rides lets say) should serve you for many years.
1 - 15 of 15 Posts
