Helmet Camera PLacement
  • Top
    Votes: 3 60.0%
  • Left
    Votes: 0 0.0%
  • Right
    Votes: 2 40.0%
  • Total voters
    5
  • Poll closed .
1 - 20 of 24 Posts
I understand the logic when someone place their cam on the center (top) of the helmet but why left or right ? Okay the top might be that it's a bit obvious for the coppers to pull you over.
Do the left/right placement point to the slower traffic, meaning LHD lanes point to the right and RHD areas point to the left ? Or it's easier for the right hand to switch the cam on and off ?
I placed mine on the right because i have a modular helmet. If placed on top of the helmet when i pull the face of the helmet up its in the view of the camera and more awkward to turn on while wearing the helmet. I couldn't place it on the left side of the helmet because of the Scala Rider unit being there. On the right hand side of the helmet it works good for me because i'm right handed so turning on and off is easy and the Drift Ghost has a rotating lens so even if the cameras at a bad angle you can make it work.
If you don't want to put it on your helmet the best place i found on the bike for a great view with no vibration is using a Ram Strap Mount and attaching a camera to the fork tube.
IMG_0175 by weljo2001, on Flickr
IMG_0177 by weljo2001, on Flickr
IMG_0178 by weljo2001, on Flickr
Weljo: your cam is using a constant 12v? If it's on the helmet, there'll be some irritating slapping of the cables. Im going to get a self powered cam with option to feed a direct 12v. Cableless on the helmet but if mounted to the bike, it'll be powered by the bike
Fork mount is a bit low to capture any "good" moments or do you think otherwise? Thanks for the pointers BTW
I have my drift ghost on my helmet hooked to a 12V outlet on the dash. The cable is plugged into the back of the camera. The USB cable that came with it doesn't slap around.I do run it between the tank and side fairing. Last weekend i had the cable plugged into a 12V outlet behind me. I like it in the dash better. The cable has enough weight to stay put.
Heres a video of the drift stealth on the fork tubes...
If you notice in the photos of my bike theres a camera mounted to the windshield bracket i use that camera to take photos.. Heres the results below...
If your wanting to use a ram mount with a GoPro...Here ya go.
weljo : Nice and expensive setup but no contest on the quality
I prefer the handle bar mounting view
Then you need to get a different bike...The vibes on the Versys will affect the video if mounted on the handlebars.
This is mounted on the handlebar footage. With the motowerks anti-vibe bar risers.
Mounted on the crash bars...
Mounted on the side of the tank with a suction mount...
Nice setup... thinking of doing this, but what size clamp did you use? did it come with the RAM mount? btw, I have the same vidcam drift stealth and a contour. Thanks!
Heres what you need for what you see in the photo..
http://www.gpscity.com/ram-mount-utility-strap-steel-u-bolt-base-with-1-inch-ball.html
http://www.gpscity.com/ram-mount-camera-mount-plate-ram-b-202au.html
http://www.gpscity.com/ram-mount-short-arm-b-socket-ram-b-201u-a.html
Heres what i did to the item in the second link. I took out the threaded piece and put a stickie mount on the flat surface that way you can just pull off the camera with out having to mess up the angle you have it set at. Also works good for a place to velcro an IPod
Heres another mounting point i use mostly for photos. Drilled a hole through the windscreen and used a Ram Ball mount thats bolted to the Windscreen Bracket. Click on photo for a better view.
1 - 20 of 24 Posts
