1 - 12 of 12 Posts
Hi
Just registered. I'm in Boston suburbs now after a move from Connecticut. Definitely more Versys here. I saw quite a few bike so far, compared to NONE ever in 2 years in southeastern CT.
Anyway, I need help with a tech issue.
An elderly women went through a red light yesterday and cut me off as I was proceeded from my side. Just had time to brake and steered right, and ended up dropping my bike. Not too much damage: my Givi case is scratched, and the front brake lever snapped.
I was trying to figure out if the lever is something I can easily change myself. Sounds pretty stupid at first, but when you take a close look, I am not sure about the brake hose and how complicated this may be. I am a DIY when it comes to woodworking, but not so much with motorcycle: this is my first bike. I just don't want to end up having brake fluid spilling all over and parts falling off as I dismantle the assembly.
Has anybody ever done that?
Plus, the clutch lever part number is listed on the Kawa website in the exploded part section, but for some obscure reason, the brake lever is not. And they are not symmetrical. It's not even there on the handlebar diagram. Anyone knows where I could get this info? (I will give a call to the local dealer, but I thought I'd ask here first).
I may repost the message in the appropriate section after the 2 messages rule is compliant and I have full access, but there it is.
Cheers.
DL
Welcome, brake lever is a pretty standard replacement and sure some of your country man will point you to the right part number.
DL, the clutch lever replacement was pretty straightforward. I referenced the thread that weljo mentions above and found it helpful. Watch for the small coil spring that maintains the tension in the lever at rest. When I took off the broken lever it went s p r o i n g across the garage. I found it and managed to put it back in the proper place by noting the round mark it had left on the broken lever...just positioned it at the same spot on the new lever when reassembling.
Is the old lady paying for your repairs?
Thanks
Thanks fellows for your post. Very good info. (my bike is black, 2010)
She is. I don't want to file a claim for 100$ worth of damages, even if I am not at fault. An insurer admitted to me in the past, in a surprising candid way, that it doesn't matter who's at fault. If you file ANY claim more than 2 per 3 years period (varies), they will put you a tag, whatever that means. I prefer keeping my rate low than spoiling my record.
Thats the 2nd time I get hit by an old boomer. Some guy bump my rear tire with his pickup truck at a light 2 months ago. My license plate bent a bit.
These elderly are a danger to themselves and other...
Thanks fellows for your post. Very good info. (my bike is black, 2010)...These elderly are a danger to themselves and other...
Not ALL of them. I'm 'elderly'.... :clap:
1 - 12 of 12 Posts
