1 - 11 of 11 Posts
Hi guys. Just thought I would introduce myself. My name is Justin. I am really looking forward to getting to know all of you. I just picked up a 2008 versus 650. I had a 2011 kawasaki ninja 1000 that I traded in on it...unfortunately i had to get rid of it as I am not doing well financially (Severe insomnia due to long term benzodiazepine use has made working all but impossible) so I was unable to afford the payments and insurance (fairly high as I am only 22). I'm definately going to miss the power of my ninja but it will be nice to have something a bit more versatile for here in Colorado and much less tempting to speed on.
I unfortunately wasn't able to ride the bike until the other day as the dealer that i purchased it from failed to address a leaking radiator cap and non-functional radiator fan relay (Coolant was boiling within 5 minutes of riding). It is now fixed and running pretty well. Anyways, I realized within 30 minutes of beginning my ride that the factory seat absolutely had to go. Not only does the factory seat push you up against the tank and away from the cushy, wide section near the rear , the continuous readjustment and sliding forward on the seat causes my Jean's to bunch up around my groin. This is leading to very painful chaffing within only 45 minutes or so. Can you guys make a seat recommendation? I have seen several online (sargent, Corbin, saddlemen, seat dynamics, etc) and they are all quite expensive/ out of my price range. Is there a cheaper alternative or modification I can make to this seat to at least make it comfortable to ride for more than 45 minutes? Thanks.
Welcome and hope you can get back to work soon. I'd go with a seat concepts seat. They send you a foam and cover and you staple it on yourself. I tried some DIY foam reshaping and raised the front of the seat with washers which helped a little but I still need a seat concepts seat.
:welcome: aboard!
...Anyways, I realized within 30 minutes of beginning my ride that the factory seat absolutely had to go. Not only does the factory seat push you up against the tank and away from the cushy, wide section near the rear , the continuous readjustment and sliding forward on the seat causes my Jean's to bunch up around my groin. This is leading to very painful chaffing within only 45 minutes or so. Can you guys make a seat recommendation?....
Raise the front of your seat - costs about $2 and a piece of scrap steel! See this link:
https://www.kawasakiversys.com/forums/74-how-forum/125578-seat-raising-front-options-methods.html
I have OVER 150,000 miles on this mod, over three V 650s.
Administrator
Welcome From Canada
:welcome:https://www.kawasakiversys.com/forums/5-member-introductions/205361-valuable-links-wizard-member-intro.html
:funnypost: OK, this is a very common problem, today it just struck me as funny, if we had a emoji that symbolized laughing hysterically I would have used it>
So my 2008 had a Corbin, which for some reason wouldn't fit on my 2015, however others have used this same seat on the 2015. Let me say one of THE worst companies I have ever dealt with, the cost between the exchange of the Canadian dollar and the cost of shipping, just can't justify the expense even if I have the $$$$
So this is what I did https://www.kawasakiversys.com/forums/74-how-forum/122466-seat-foam-modifications-diy.html See posts 28 through 31
:welcome: aboard!
welcome. listen to fast eddie. the problem is the tilt of the seat. raise the front "a la methode de fast eddie". voila. easy and cheap cure. as onewizard said, this is an almost universal complaint with the seat. other than the tilt, I find the seat is fine for touring. if you marathon ride long enough and far enough, you'll get butt rash/sores, irregardless of seat.
...this is an almost universal complaint with the seat....
I joined the Forum in July '08, and the "fasteddie solution" was one I got from the FIRST Versys Forum inmates, way-back-when, and the FIRST 'mod' done to all THREE of my V650s!
(I'm just "passing it on"!)
Eddie I am having difficulties viewing the link you provided. I recieve a message stating I do not have the permission to access that page. Any idea why this may be? I think your mod will be the solution...the seat is comfortable near the rear I just slide down from there continuously. Now, if only I could view your instructions...
mrvwbug I live in Fort Collins
Thank you everyone for the warm welcome!
Eddie I am having difficulties viewing the link you provided....
Take a scrap piece of steel, drill two holes in it, then remove the piece (at the rear of your gas-tank that the "lip" at the front of the seat goes under), and use two LONGER (I use 6mmx45) bolts as well as some 1/4" washers (I use 12 - six per side), and attach the piece of steel you 'made'. Raises MY seats by about 9/16".
1 - 11 of 11 Posts
