1 - 10 of 10 Posts
Hello i am pride owner of a Versys 650, 2015 model. It is 1st attempt with bikes until now i used to ride scooters. Thank you for accepting me.
Στάλθηκε από το SM-G920F μου χρησιμοποιώντας Tapatalk
welcome to the forum!
Read up on maintenance and how to survive on the roads- You've picked a great choice for your entrance into the motorcycle world...
:welcome:
Welcome! You can download the service manual from the tech section of this site.
BTW there is a Greek manufacturer, or was, of a rear fender/tire hugger for this bike. I purchased mine from EBay several years ago from Greece. A rear tire hugger is a worthwhile option as it keeps road grime off the spring/shock (perhaps making the seals last longer) and voltage regulator (which can overheat if covered in gunk - not sure if they moved this to another location on the MK III bike).
You'll also need swing arm spools (10mm for MKI and MK2 bikes, 8mm for MK3 bikes) and a pit stand to perform maintenace as there is no center stand. Spools are cheap on EBay.
1 - 10 of 10 Posts
