1 - 12 of 12 Posts
Hey all. Had a hell of a time tonight fitting these to my 2015 versys. I got the clutch side on no problems but the throttle....
I only got it on 80% I used the super glue that came with it. Probably should of used hair spray. Anyhow, any suggestion on how to get it off? Suggestion I have read are to start the bike and let the grips heat on full then twist back and forth to remove or break the glue. Try squeezing acetone or super glue remover down, that did not work at it simply came out the throttle sleeve the other side. Any other ideas? I would like to salvage it if possible but if it's a right royal pain then happy to cut off, hopefully that works without stuffing up the throttle sleeve. Nightmare all around really.
Thanks
heat, a thin screw driver, air compressor, lube, and most importantly time!
try getting the screw driver under the grips (not to pry) then spin it around the bar braking the glues bond from grip to bar. spray some wd-40(or lube of your choosing) spray in UNDER the grip then if you can apply air under the grip as you pull it off
https://www.youtube.com/watch?v=zyrPOSai4wc
You will most likely have to destroy the throttle tube, removing the tube from the grip, not the grip from the tube.
A couple of years ago I replaced an Oxford grip and if I remember correctly the replacement grip was approx. 60% of the cost of a complete grip kit.
The question is which is less expensive to destroy, the grip or the throttle tube.
When you attempt installing the grip do a test dry fit to make sure the grip will slide completely onto the throttle tube.
If not remove material from either the grip or tube.
The grip has an inner tube that is a hard plastic material.
Hmmm well heating the grips didn't really do anything. I do not really want to muck about with the throttle sleeve so would cutting the grip off be OK? I don't want little bits of grip stuck to the sleeve but I guess I might have to deal with that! For $110 it might be worth the effort of just destroying the grip and notching one up to lessons learned, and yes I only fitted it 80% dry I thought the glue would provide enough lubrication to go the extra 20! I was wrong.
On a side note does anyone know where I can get a throttle heated Oxford grip only? In other words just the spare part?
Thanks, they don't ship to Australia sadly so I have contacted a distributor, see how I go. It looks like the throttle tube is easy to remove/replace so I might go down that path of replacing both components. Two screws and some fiddling looks to be about it after inspecting tonight and dissembling of throttle housing.
Grip removal--Windex
I am planning to buy the Oxford grips for my 13 V650. What I have found best when installing/removing grips is Windex. Not sure how it will work with glued grips though?
Cheers,
Mickey
Having done a couple sets of the Oxfords I found that you have to "Fine Tune" them a bit with sand paper to fit correctly. I then use a bit of soapy water to make sure they fit all the way and after washing all the soap off I dry and then cover the bike with plastic, no drips of glue please, and then I have at it. Both times they have seated fully and no problems.
I'd check with your Kawasaki dealer I bet it's cheaper to replace the tube than the grip.
Yes I didn't fine tune enough sadly! I think the clutch being metal tubing went on easy so I (wrongly) figured the throttle to go on easy too. In any case I have ordered ($32) a new throttle sleeve so hopefully I can dig the old one out of the Oxford grip and recover it. Any suggestions on how to do this? Next time, hair spray and test fit allllll the way down!
Measure the diameter of the hole in the grip to determine its size and try using a sharp drill bit the same diameter of the grip hole to drill (bore) out the throttle sleeve starting at the outer end of the grip.
Go slow and be patient.
Remove any remnants of the throttle tube with a rat tail (round file).
Well, one ruined heated grip later here I am! I have ordered a new one for $50 so not too bad, lesson learned. I also have installed a new throttle sleeve and grip. Bit of a pricey exercise but things happen I suppose! I am now trying to find a longer screen for the bike. I just taped some thick cardboard to the screen to see if that makes any difference. I don't want to spend $300 ish only to find it does nothing extra. Not sure how else to test apart from stylish looking cardboard duct taped to the screen!
1 - 12 of 12 Posts
