1 - 16 of 16 Posts
Looking at adding heated Grips and Bark Buster's to my 16 Versys. Wondering if anyone has any experience with the Tusk brand of these things. Everything I've gotten in the past has been solid. I'm a little skeptical that the throttle side trip will have the correct cable adapter, but the install instructions show multiple adapters just like the ODI stuff. Had anyone installed either or both of these?
I didn't search yet but are there any issues getting the stock bar ends and grips off?
https://www.rockymountainatvmc.com/p/709/68071/Tusk-Lock-On-Heated-MC-Grips
https://www.rockymountainatvmc.com/p/1036/83735/Tusk-D-Flex-Pro-Adventure-Handguards-w-Turn-Signals
Heated Grips
Removal of OEM bar weights, most important is good quality tools, as the mounting has a overabundance of blue loctite on it and due to this is also over torqued.A allen socket and impact driver could help, be aware it is a standard right hand thread ( CCW to remove). I removed my OEM grips in one piece , yes difficult, most just take a box cutter to them.
As to hand guards, make absolutely sure these are specific to the Versys, not all fit, also the bar end weight gets changed out with the Barkbusters. Heated grips I provided a link https://www.kawasakiversys.com/forums/74-how-forum/208209-heated-grips-relay-cct-post-39-kawi-koso-oxford-oem-poor-performance.html Two of the top performing and selling are Oxford and Koso. I have the Oxford but, had I waited until this year, I would have gone with Koso, as real-estate on the Versys is limited.
Those Oxfords are great,i had them on high yesterday.Very toasty.I put the controller on the handlebars with 2 mini zip ties and some double sided sticky tape.
Thanks for the replies and the information. I did research removing the factory bar ends and I think I should be fine there. I did contact Rocky mountain regarding the Bark busters and they told me that the adventure version that I posted a link to is the correct one for the Versys. I am very tempted to try the Tusk heated grips as I like the Motocross style grip because that is what I am used to. The few reviews on them are good but there are not a lot of them. I will definitely check out in the Brand's you suggested as well. Thanks!
I have the KOSO APOLLO heated grips on both my V 650s. They work PDG, and as the controls are on the left grip, they "blend-in" better.
I've since rotated the right grip so that the wire doesn't point upwards.
Does anyone know if I will be able to tie the led lights in the handguards in to the stock turn signal without any issue? I don't want to get rid of the stock blinkers, just add the led handguard blinkers to them.
You should be able to add the LED's without issue, if they are low wattage. Worst case, the turn signals will flash slower than before and you will need a $2 adjustable flasher relay to get back to the correct flash rate.
Easy peasy , you can save yourself a bit of work by tying into the harness at the signal lever, if you need colour codes, let me know, I thought they were in my https://www.kawasakiversys.com/forums/74-how-forum/119770-led-city-lights-led-signal-conversion.html page 2 post 66 on but a quick look, not so.
Cool. I did do some research and I think I am doing all of the below:
Tusk Adventure handguards with LED (Link in original post)
Tusk Heated Grips (Link in original post)
LED Bulbs for All 4 blinkers (The amazon ones suggested on this site)
LED Flasher from superbrightleds.com (Also suggested from this site)
LED Brake Modulator to tie into the stock LED brake light https://www.amazon.com/gp/product/B074WYMZ4S/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thanks for the input. The only think I am not 100% sure about is the Tusk grips, but they went on sale for $44 so I will give them a try. I am thinking I will be able to tie them into my stock heated grips connection up front on my 16 versys instead of going to the battery.
...Thanks for the input. The only think I am not 100% sure about is the Tusk grips, but they went on sale for $44 so I will give them a try. I am thinking I will be able to tie them into my stock heated grips connection up front on my 16 versys instead of going to the battery.
You will be able to, AFTER installing a relay, which goes behind the right-side head-light. (I got mine from Ma Kawi for about$16CDN.)
Cool. I did install a relay (just used a standard $4 relay and removed wires from stock connector) already as I installed a gear indicator so I should be good to go.
:thumb: - :thumb:
I just installed Oxfords on my 2016 Versys 650. I was trying to figure out how to connect them to the factory wiring, but just ended up connecting to the battery. Where did you connect yours to? I'd like to connect to the factory wiring if possible. Any info. would be appreciated.
I installed the Oxfords last weekend and they work great. But, I had a difficult time finding a place to mount the controller. I had to cut the bracket and just use the square part that screws on to the controller, then zip tied it to the bars for a temporary fix. Any ideas or suggestions? It's a 2016 Versys 650.
You can't go wrong with the Oxfords. They are a proven design and easy plug in install. They also have a digital controller that switches itself off if the battery runs low. I ordered a no name kit from ebay similar tho the set linked to and it did not fit.
The OWNERS MANUAL for my '15 has a page showing the various places that the OEM wiring is already set for adding heated grips, lights, and and gear-indicator once you add the required relay. I expect it should be in yours, as well.
1 - 16 of 16 Posts
