I've recently bought a used 08 V with Oxford Heated Grips installed. (Nice, since I live in Maine!) I snuck out for a very brisk ride this Christmas morning, and had the grips set on HIGH for the first time. After a while I noticed that the grip was slipping backwards on the throttle tube! I assume I need to take it apart and re-glue it, but WHAT SHOULD I USE? I didn't install them, so I can't say if it was done right the first time, and don't have any manufacturer instructions. I'd love some advice. Cheers, Chris.
Use a VERY SMALL amount of this just around the ends. Spray some into a small container (like a bottle cap) and apply with a q-tip or stick. Run a ring about 1/4" (0.5cm) wide. Careful, too much and you'll have an impossible time getting them off.
