1 - 19 of 19 Posts
Currently I wear a pair of "snore blockers" while riding. These earplugs are great, probably some of the best I've ever used. They will block the lady's snoring and the construction noise at the office out completely. They also do extremely well at blocking out gun shots to the extent that shooting a 75 round rifle match causes me no discomfort. However, after riding my Versys I sometimes have a persistent ringing in my ears.
Since I do not want to lose my hearing I am looking for a recommendation on a better option for controlling the wind noise. I have the Givi tall screen on the bike, but at 6'2" I still take a fair amount of wind. I have considered getting a different helmet, but that is expensive. I've also considered getting the Givi windscreen extender but I do not like the look of it at all.
Any input is appreciated.
I have something similar to these. The key word is "active" noise cancelling. A bit fiddly when putting on helmet but I manage by spreading the helmet a bit farther. I think mine have 30 DB for noise cancelling, that could be a bit of a difference.Mine also came with a 60 hour battery and switchable base boost(at the expense of losing the "active". Mine also came with three different size inserts. I looked around but could not find them.
Sony, Bose, Etinomics(sp?) and others also make them.
https://smile.amazon.com/TaoTronics...9AGP2RYMN&sprefix=active+noise,aps,179&sr=8-3
ear plugs, foam
I use these Stanley ear plugs, and have for years (tho' I buy them in containers of around 100, usually at Home Depot).
https://www.walmart.com/ip/Stanley-...MI9Iny0vPJ5gIV5B6tBh3psQBYEAQYASABEgLJv_D_BwE
I wear two hearing aids when NOT riding, and I find that these plugs (32 Db rating) allow me to be aware of my surroundings, and not give me tinnitis - ringing in the ears - when I remove them OFF the bike.
When I go shooting at the range, I usually wear the plugs UNDER my over-ear hearing protection.
I have been using Moldex Pure-Fit earplugs. Best foam earplugs I have found.
They look just like the snore blockers...humm?
Thinking they both come out of the same warehouse somewhere in good o'l Chiner.
https://www.amazon.com/Pairs-Moldex...ZY18VG6P37W&psc=1&refRID=2ETCSWQ6PZY18VG6P37W
You're right on point about the origin of most things these days. The snore blockers have a different shape to them where they taper in then flare out at the end; I think the shape has been the key to how well they work in other circumstances.
Thanks for all of the input; I am going to look through them after dinner tonight and order something new.
I use cheap foam earplugs (1 pair cost 0.22$ ) I think it is NRR 32db.
Plus I have wind deflector from aliexpress for ~20$.
Those two things improved my travel experience by 100%, no buffeting, and no loud noises.
I use the silicone style from Earpeace. Simple but effective. Foam type are excruciating after a couple hours for me. Similar noise block but all day comfortable. Worth the $25 or so to me compared to the price of custom molds.
Fwiw, my 09 V650 is what triggered my ringing after nearly 30 years on street bikes. 😞
Mighty Plugs
I have tried numerous different types of earplugs in the past 20 years or so. However they all hurt my ears after medium to long rides.
Eventually I discovered Mighty Plugs and have been wearing these for the past 4 years or so.
These Beeswax Earplugs are very soft and will shape to your ear. For motorcycle riding, I cut one pill in two and then kneed each one before inserting one into each ear.
If I'm at a noisy motel, etc., I use 2 full plugs. It works for me! :D
Check the video at Mighty Plugs for detailed explanations.
I used to use foam plugs, but then tried some silicone ones I got on Amazon that are designed for motorcycles. They block out the high pitched wind noise, but don't block out the road noise like foam plugs do. I'll never go back to foam plugs.
Discussion Starter #13
Thanks, mine will be here Tuesday.
Any foam earplugs work great. Shoppers Drug (in Canada) or I suspect CVS (in US) or any other comparable chain, sell these. Just be sure to roll them between your fingers to compress first or you will have a problem inserting.
Wind noise is the culprit.
Discussion Starter #15
I ended up getting both the motorcycle earplugs (link below) and the clip on windscreen spoiler. The difference is astonishing, mostly due to the spoiler however the new earplugs are not bad either. After two rides in the South Alabama country I have zero bugs on my visor and a very dirty spoiler. I know that bugs were not the problem I referenced but they serve as a good proxy for the effect - my visor is spotless.
The earplugs recess down into the ear canal and have a pull tab for removal. They do not work themselves out, as foam plugs can; I believe my problem began with the foam plugs working themselves out over the course of the ride.
A bit off-topic but I also picked up a new HWK jacket with the plugs/spoiler as my leather jacket was not comfortable in the Versys stance. I am very pleased with this jacket and it has preformed perfectly in the 60's weather I've ridden in all week. The first ride I turned around after filling up with gas to remove the liner; therefore I expect it will perform well in 9 months of South Alabama weather. One of the best aspect is that at 6'2" I still have room in the sleeve length to keep covered.
Earplugs: https://www.amazon.com/gp/product/B07HY8L5R3/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Went to amazon, several problems, NRR rating if you do research, you will find that the rating of NRR is recommended to be reduced by 70% according to Niosh https://www.protectear.com/nrr-rating/ . I have very sensitive ear canals, my hearing loss is 27DB at 1500 HZ , I need to watch my right ear canal on a hourly basis, right now, I have had to reduce the dome size in my right ear for my hearing aids. The foam plugs I use are low pressure compressible disposable. That site gives very few options for fitment, some negative feedback. Nothing like being able to try things out and if they don't work, return for money back.
I played in bands for years.....loud electric guitar and often times on a small stage so I've got cymbals right next to me. I've used musicians plugs for decades. They idea is they're supposed to reduce all frequency levels equally. (or at least attempt to) The bass frequencies will be increased a bit, because your body will vibrate a bit and help communicate those low frequencies. I just tried to have the bass player set up on the other side of the stage.
But they seem to work well for motorcycling. I'm new to cycling, so I don't have a wealth of information. I 'think' my helmet is really loud from the wind. The windshield of the versys helps, but I get hit mid face with the wind even with the windshield all the way up. So I buy musicians earplugs with the highest rating I can find.
The squishy foam style make things sound like you're in a padded closet. Everything's muffled.
+1 on the Earpeace.
1 - 19 of 19 Posts
