Handlebar Risers
4911 Views 9 Replies 7 Participants Last post by  HAWKSHOT99
I got these off of ebay for $30 bucks shipped, and they fit as described.
https://www.ebay.com/itm/Handlebar-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
so if you are looking for inexpensive riiser that works as described, offer $30-$32 on these and you'll like them.
1 - 10 of 10 Posts
I use ROX 2" Risers on both my V650s, as w/ ROX you can change the orientation, closer or farther as necessary, while the ones you showed can ONLY come towards you as they rise.
Thanks for sharing. I am thinking Rox is what I need. As I need the bars to come back to me a bit. My V650 fit me like a glove with no riser modification. But this bike , I am finding the bars to be a little wider, or they do not sweep back as much as the 650's? Am I imagining things? I seem to be leaning in more than the 650.
regarding ROX: i have heard and read varying opinions about needing to make cable/control modifications when installing these. does anyone have knowledge of that for 2017/2018 1000LT?
jim
jim
Can't say for the 1000LT, but NO ISSUES on the V650 w/ the 2" ROX.
Reactions: 1
Just FYI with these, they have a pretty slick powder coat on them including the inside of the riser where the bar goes.
I ended up using a dremel to rough up the inside so that the bars would stay firmly positioned.
I just cut shallow groves similar to the groves already on the bars, works fine now.
This are not adjustable, but the risers are already angled back a bit, so these just continue on that angle. so they end up being up a bit and back towards you a bit. maybe 3/4 of an inch each way. Just enough to make a difference to me. I've done one ride with them and I could tell the difference. Less pressure on my wrists.
I put 3" ROX risers on my 15' 650LT cause I wanted more height and back closer to me. they worked great. I had to re-route the clutch cable behind the triple tree, everything else was a fit. The front brake line was close but did not put any tension on it.
For those with short arms.
Reactions: 1
I have the same risers but... the my handle bar keeps on slipping so I had to put a rubber for it to hold. its kinda bouncy but it doesn't slip and move.
... my handle bar keeps on slipping so I had to put a rubber for it to hold....
THAT sounds a little 'dodgy' to me. I use ROX RISERS on all three of my V650s, and IF they "slipped" - that, TO ME, is unacceptably DANGEROUS.
After talking with Eddie a few yrs ago I added rox risers as well and have been super happy.
1 - 10 of 10 Posts
