My response was just light hearted fun.
Seeing your reply it sounds like something is loose on your bike and is the source of your problem
I had a 2015 V-650 and put 22,000 miles on it and never had the extreme kind of vibration as you are describing.
Try running the engine at various rpm's, without actually riding the bike, to try and duplicate the vibration so you can locate the source. Most likely there will be a certain RPM or RPM range that will produce the vibration. If you cannot pinpoint where the noise is coming from, have a friend hold the throttle at the RPM causing the vibration so you are free to walk around feeling and pressing on everything on the bike. Fairing, windscreen, headlight, gas tank, engine, frame, etc. Don't stop this process until you have isolated the problem area.
Once you locate the culprit make sure all the fasteners are tight and secure. If the vibration continues try some thin rubber as a cushion between the vibrating pieces. If this does not work you might consider some silicone or RTV as a vibration damper.
Good luck.
