grips...question regarding bar size
425 views 5 replies 2 participants last post by  Cap77
#1 ·
is the throttle side larger diameter?
some dude on Y-tube showed the right side grip with larger inside diameter
He also cautioned about cutting too deep removing stock grip due to plastic tube/throttle mechanism
are Versys specific grips needed?
or any grip for 7/8" bars work?
thanks
KTF
#3 ·
. The grip kit will take this in to account
grip "kit"?
With stock grips off, I discovered the throttle side is 1" (actual 1.01 according to my calipers)
left side 7/8"
I made these cheapies work for now
Speedmetal Foam Grips - Cycle Gear4
They're for 7/8" bars, but there was enough stretch to soap and slip on throttle side.
I bought them just in case the better grips I bought wouldn't fit.
Glad i did .
I'll take back the others tomorrow
my bright idea now is to find the grips I want for 1" bars and wrap/shim the left side
KTF
#4 ·
Even looking at the grips you have pictured I can see that they planned for the 2 different sizes. The end caps are different. One of the grips will be thinner to fit the throttle side while keeping the outside diameter the same as the clutch side. They even included a ring to keep the grip from sticking at the switch housing when it is rotated.
Grip kit just means a package with both grips in it.
#6 ·
hold the fone, I'm an idiot
donno about the $7 dollar foam ones, but just mic'd the better ones.
sure as sheeit one is larger I.D.
I was trying to put a square peg in a round hole with the wrong one on throttle side :oops:😞
KTF
