1 - 20 of 22 Posts
who has done it? was it worth it? any suggestions?
there is also an Italian cart kit... thats a "maybe" if it is really good
I have an Ohlins rear shock
Gen 3 650 Fork Revalve
I don't know anyone who has revalved a Gen3 650 with Race Tech's Gold valve, etc.
However I can tell you that I have revalved mine (compression and rebound) in March 2018 without using the Gold Valve.
Since the Gen3 OEM 20mm fork valves already flow pretty good, I decided to massage them and clone Race Tech's revalve system.
It takes time (lots of testing) but I'm very happy with the results.
I need to find some time and try to write up some steps to follow. It's similar to what fellow riders have done for their Gen 1 and Gen2 Versys. However, instead of grinding valve shims, I decided to use new shims as does Race Tech.
so.... spill. what did you use & why. thanks!
Every bike I have put gold valve cartridge emulators in is because it needed it, and in every case was a vast improvement in suspension compliance without becoming mushy.
Kawasaki actually recommended running 28 PSI in the front tire of the Vulcan Voyager to compensate for their piss poor fork internals. When it was at a dealer getting the engine issue diagnosed they had to keep doing things and riding it. I came to check on it and they immediately quizzed me on if I had done anything to the suspension because it was THAT NOTICEABLE! Definitely the least expensive way to vastly improved suspension performance upgrade.
Very interested in how people have improved the MK3 forks, aside from switching to ATF, which I need to try. The Andreani cartridge kit is high on my list after the improvements the R1 shock made in the rear, but if gold valves are effective and less expensive I would be onboard for that.
Reactions: Beezerboy
yea.... what he said. I switched to ATF, it's OK but not a lot of difference. I thing theres room for a lot of improvement
No Video
The main difference is that once you get the Gold Valves set to your liking you are going to keep them that way for the long haul.
The Cartridge kit usually comes with external adjustment for compression and rebound, so if you are the type who changes settings for the nice twisty road and change them again for comfort on the interstate, you will want the adjustable cartridges.
I'm fine with something that works well most of the time. I have no need to twiddle knobs just for the sake of it. this bike will is mostly highway and some gravel roads. I'm not blasting the twisties, I'm not pounding the woops. surely there is an ambient setting can cover that.
Race Tech will provide a good initial setting for you. Some guys end up fishing them out a couple times adjusting, but that really depends on what other suspension you have experienced and how bad the stock suspension is. I found their initial setting much improved that I didn't want to bother fishing them out and adjusting.
Have you checked your current sag on the front forks to determine if you should go for new springs as well as the GVEs?
For the Versys 650, Racetech furnishes Gold Valves ... not gold valve cartridge emulators.
These Gold Valves replace the OEM valves in our right hand side fork. Along with these valves, they send a bunch of valve shims and basic instructions as a baseline to get started.
Once done, the rider has the same adjustments as with the OEM setup ... but with a much superior suspension.
I cloned that approach ... using the OEM valves (modified) along with the suggested valve shims.
As mentioned earlier, I need to gather my data and put it in logical sequence to print.
I forgot the 3rd gen were improved over the previous generations.
Your write ups are legendary, looking forward to it.
Yes the Gen 3 suspension is improved. However Racetech has the same approach & instructions for the Gen 1 & Gen 2 Versys: Gold valves (rebound and compression) + a bunch of shims.
Discussion Starter #18
I did Q's mod on my Gen III forks using the data he posted in another thread and wow.... much better. total cost was about 30 bucks, including the fork oil. someone should consolidate that data and make a sticky..... its really worth it. and a big thanks to Mr Q!!!
Reactions: quexpress
Good job! Thanks for the feedback! I'm very happy to see that the write up was useful to you. :cool:
How long did it take you to perform the mods? And how familiar were you with suspension work beforehand?
Curious if I can do this mod in a day or two along with a tire change soon.
1 - 20 of 22 Posts
