1 - 5 of 5 Posts
Working on a windshield setup for cooler weather, so maximum coverage. I cut down an old '70s bar mounted Plexi-fairing to fit the Versys and mounted it up. Only had time for a quick run, but it seems to do exactly what I had hoped for. My only concern is the stress I may be putting on the mounts. I left the shield huge, at about 21.5" along the centerline. The leverage of that shield makes them bounce a it, especially at slow speeds over bumps.
Are these mounts up to the task of holding this huge shield, or am I better off cutting this down some more?
I know there are at least a couple very large screens for this bike available and I would love feedback from those who have run them.
Here's a pic of the monster
Over time and miles, the factory brackets may fatigue and crack. I know there are a couple examples of that happening with larger windshields. I can't say for sure it will happen to yours or under exactly what conditions it may happen but I wouldn't be surprised if it did.
Thanks. Looks like I better break out the angle grinder again and chop it down. I guess it would be better to have the bracket fail than the piece it attaches to, but I'll try to avoid both.
...Are these mounts up to the task of holding this huge shield, or am I better off cutting this down some more?
I run a pretty large 'shield in the winter (or long rides where rain is an issue),
and I had the stock mount fracture,
then got it welded - TWICE -
but then I got a Madstad adjustable bracket which solved that problem....:goodidea:
The 'killer' was riding washboard dirt, which caused the larger 'shield to sort of "whip" which took its toll....
Thanks. Exactly what I had feared would happen. In my case it was paved roads with a lot of poor "patchwork" style repairs done that caused that bouncing effect. It didn't inspire confidence.
Good to know there's a more solid replacement if/when I have to. I'll concentrate on a mini summer shield, which is also something I've been meaning to do. I've seen a couple that people have made that looked quite decent. I took it around this weekend with no shield, and in the near 90 degree heat, it felt pretty good like that.
1 - 5 of 5 Posts
