1 - 19 of 19 Posts
Alright guys I picked up a 2012 versys with 3600 miles on it a couple weeks ago and have noticed two things. After I wash the bike water is collecting around the gas fill opening and it's not draining through the overfill hose which leads me to believe it's clogged. Also I noticed when filling the bike up that when I open the gas tank there is pressure that blows the water sitting (not draining) all over my bike. Any help would be appreciated.
if you have an air compressor try blowing it our with that,
does yours still have the charcoal canister or has it been removed>?
Kink!!
Also - take a look to see IF the hose has been "crimped" or otherwise "kinked" by the OP, accidentally.
Kinked or crimped.
My '13 was like that.
Remove or loosen left side fairing. Pull hose from bottom, youll probably a kinked or pinched spot. I had to wiggle tug and jiggle it around to see where it was crimped. Once I freed it up it was no problem. Originated from factory like that and not unusual.
Easy fix.
Kinked or crimped.
Easy fix.
Ok thank you I will have to do that tomorrow.
It still has the charcoal filter, should I remove it? Thanks
its a personal option, if you leave it on and over fill your gas tank it can cause problems starting and running the bike
A lot of people have, myself included. You get almost 1/2 gallon more fuel capacity and the removal of an unsightly tumor from the left side of the bike.
I had the same problem after washing my bike. At first I tought it is a clogged pipe. So I bought 1.5m steel cored rope (4-5mm diameter) with rubber cover. I slowly let the rope through the top hole to the bottom exit but couldn't get to the bottom. After that I followed through the pipe with eyes and saw the the twisted pipe. After fixing the pipe the rope passed all the way down easily.
Thanks I just removed it.:smile2:
:wink2: GOOD choice. Just make sure the right lines are capped and or routed properly. IF it's done wrong I've heard of problems cropping up.
Awesome, I am not in California, I just removed it today. Also how exactly does this increase you gas tank capacity. Thanks
W/ the 'tumor' installed, you're WARNED not to fill the gas tank ABOVE the bottom of the neck, but w/ it GONE, you can fill to the TOP (another .4 USG), altho' I ONLY do so when I'll ride at least another 15 or 20 miles before parking it (use this on the long trips I do).
Jeff's CORRECT.
In a thread about removing it, invader showed the correct way to do it. MIGHT be in this thread:
http://www.kawasakiversys.com/forums/9-technical-discussion/15897-fixing-hard-open-gas-cap.html
Discussion Starter #18
Jeff's CORRECT.
Thank you, I am still a little confused, Will I be doing any harm to the bike if I just remove the canister and don't cap anything off, I still have the overflow/vent line there, just removed the canister. Thanks
If memory serves me you need to cap one of the two fittings on the tank while making one a vent hose routed down to the ground. Then there is one line coming from the FI intake area of the engine that gets capped as well.
1 - 19 of 19 Posts
