I ride my Versys 650 year around, and I've always been pretty diligent with maintaining it. Cleaning the front of the drive, making sure the chain is oiled and lined up, tightening the chain, replacing it when needed, oil changes, keeping the tires filled up, etc. But my gas mileage has been getting worse, and worse. When I first got my 2016 Versys 650 a couple years ago, the mileage was pretty reasonable. I was getting around 42mpg average? I was also still learning the bike a bit and was still a pretty new rider.
I have gone back through and checked that the clutch cable is adjusted to the proper setting, and adjusted the lever positions to be more suited to me. Just lubed the clutch not long ago as well. It has close to 12000 miles on it (had 2800 when I bought it).
The mileage has dropped to 32mpg. It gets ridden mainly in city, but even going across state the gas was eaten up really fast. I always, except when in six gear, keep it under 5k RPMs and above 4k RPMs since it seems happiest in that range, and the economy icon is on normally in that range. I hard accelerate when getting on the freeway but overall tend to keep it within reason on city roads. Only other thing that may contribute to the cruddy fuel economy might be that because I have to scoot my bum off the seat to get a foot down, I will sometimes balance on it and creep if the light looks like it's going to be turning green momentarily. But I don't think that'd do a lot? I've gotten pretty good about balancing the clutch, throttle, and rear brake when doing that.
Any idea what could be causing it?
I should note that I've added a bit to the bike since I got it. Crash cage, center stand, risers, heated grips, aftermarket levers, luggage racks, top case rack.. Probably other stuff I'm not immediately thinking about. I do tend to use the top case, and the waterproof saddlebags on it pretty regularly. Here's a picture:
Thanks for the help!
