1 - 20 of 28 Posts
Every time I go to put gas in my V the gas cap lock seems seized. Trying to turn it with the key just bends the keys. The only thing that seems to work is fooling around with the key for 5 min or so until you hit that sweat spot and the key can turn the lock without resistance. When I do get it unlocked it seems to function OK and I cannot tell what caused the issue. Any ideas?
Used to wash my bike once a week and after drying would shoot a little WD-40 into the gas cap lock and never had an issue. Then i got a keyless gas cap.
IMG_0016 by weljo2001, on Flickr
Try pushing down on the cap while turning the key. Should release pressure on the locking tangs letting them release easily. I do this closing it as well, press down and turn the key to lock it.
The same thing happened to me. In fact mine completely seized up on me. I had to take the cap off the bike.
Maybe you can take it off the bike. Spray wd-40 in there and shake all the excess out. That's what I did and mine works great now.
i put a couple of drops motor oil in the key slot and let it run down, turns very easy now
Both the above are highly recommended.
You will not have any problem and better to get a steel key to replace the original aluminium one.
weljo2001, where did you get the gas cap? Vortex I know makes one, but I have seen "cheap"er ones on flea bay. Not sure if they're worth it or not.
It was from e-bay. Sold from a hong kong vendor can't remember who. Have had it on the bike for well over a year and it still looks liked it did the day i bought it. The price with shipping was $32.00
I had the same thing with mine. I found the problem is with the vent hose on the left side of the bike. Take the side fairing off and lift the tank a little and you will see 2 hoses on the left side. One will have a crimp in it. Straighten it out and move the wireing harness up alittle so the hoses move free in there and that will fix your problem.
use sewing machine oil for lubrication of all locks, as WD40 is not permanent.
And always carry the duplicate key with you when you ride!
May not be permanent but WD40 is quite safe for locks. I have a locksmith friend who swears by WD40 for a lock that's getting sticky. Have been using it in vehicle locks and house locks when the lock needs some loosening up and have never had any bad affects.
Have not thought of sewing machine oil. I imagine it is quite light and would not gunk up!
+1. Read a story on another forum about a guy 5 hours from home who dropped his only key in a storm drain 5 hours from home. He spent the night at a local hotel while his wife overnighted a spare! Vowed that was not going to happen to me. :thumb:
OK only one of the following links, specify the cap will fit the Versys.
Someone enlighten me. Which Kawi caps are interchangeable?
All the Kawasaki caps shown with 3 mount bolts fit, but not the ones shown for a 500... Show me the one you're interested in.
That's just a rain water/gasoline spill drain tube. Air flows freely around the cap and down into the mentioned drain hose. It has no effect on cap vacuum buildup. If the drain hose does clog, rain water accumulation may contaminate fuel in the tank.
http://www.kawasakiversys.com/forums/showthread.php?t=9543
Not sure , but if all that have the 3 holes work. That's all I need for now.
I found that pressing down on the cap before turning the key works fine. This is good info for later if needed.
Thank you sir! I will likely grab the one from shipping from CA. Probably still made from somewhere across the water, but won't hurt to support a retailer this side of the pond. :usa:
A better product IMHO than WD-40, at least for locks, is Lock-Ease. Last's longer and works better. If you have an Ace-Hardware nearby they should stock it, if not Amazon has it as well.
Ditto: Started carring a spare key because of an incident i had while at the bank a couple of weeks ago. Was going to put the key in the ignition and it dropped it landed along the frame in the middle of some cables. With the lack of a flashlight couldn't see it so started rocking the bike back and forth and side to side with no success. Finally after about 15 minutes was able to get my fingers on it and knock it loose. So i keep a spare in my back pocket from now on.
The best thing for locks is a dry lubricant. oils will attract dirt and gum up the works. WD40 fits this bill but there are other alternatives that work better....
If you wash the bike WD40 the lock then after it drys use a dry lubricant. Should be GTG.
I agree carry a spare key....they tend to break even with just a little pressure. BTW Hemostats work really well for getting busted keys out of locks....I added one to my tool kit.
1 - 20 of 28 Posts
