1 - 4 of 4 Posts
My Roommate's V fell over on its left side and now the fuel gauge doesn't work.
Anyone have a similar situation?
Thanks for the help!
How is it not working? Is the display itself not working or does it read full/empty all the time?
If it's giving a bad reading it's possible the sensor in the tank was knocked loose. If it's the display check the connection.
If you remove the tank, on the underside, in the middle is the fuel level sensor. I would check the connector first.
Sent from my LG-P500h using Motorcycle.com Free App
2017 300X with many mods
I have the same problem with my 2017 X300. Dropped on left side now fuel gauge only shows full. Is the fuel level sensor in the same place as the V650? If it has been knocked loose, how can it be repaired?
1 - 4 of 4 Posts
