1 - 15 of 15 Posts
2009 Versys fuel gauge had one bar and began flashing "FUEL" at ~190 miles. At 193.7 miles on the odo I filled the tank putting 4.28 gal (45.2mpg). Fuel tank capacity being 5.0 gal the range would be ~226 miles. It would be hard to argue that erring a bit on the conservative side for a fuel warning signal.
If you are relaying that there is not much range left after the warning starts blinking- not sure.
I often roam alone, and it's funny how fast the gas gauge on my '08 can go from a couple blips down to one....
I wish sometimes the V had the same size tank as my old KLR, that would make it dandy. But I suppose it would also make it more top heavy.
Sometimes I find myself staring at that single bar-blip mark on the empty end of the fuel gauge, and wondered if I would make it to civilization or a town with fuel.
A couple years ago, I started carrying a large PRIMUS bottle, it's rated for carrying gas. It's 1.5 L I believe (or biggest one of this design), about $25-27 bucks.
I can fuel/fill it in-place without having to remove it, plus it accepts a gas-station size pump nozzle.
It fits nicely on the one side behind my SW Motech side rack-- just opposite a tool tube. Math not being my thing, and I am not great with the metric system, I am thinking this might take me 15-18 miles as a reserve. I have not had to use it, but I do keep it full of non-oxy premium, and rotate the contents with fresh once in awhile. Even if I never need it, maybe I will rescue some maiden on the Harley that's broke down and my KARMA will suddenly change?
I have it on a bottle-rack from Twisted Throttle with a hose clamp. It's actually smaller/shorter somewhat in contrast with the tool tube on the opposite rack.
Naw, it's not a gallon or anything, it's just an appetizer sized amount I can easily carry and forget about for the most part, until maybe I need it.
Not sure what the O.P. is asking, but I look at a motorcycle fuel gauge as a rough guideline. I would guess there would be like a 10% variance in accuracy from one V to another. As Clint would say: "A man has got to know his limitations" (and the range of a full tank). Also, when I am looking for maximum range I hold the bike straight upright to use all of tank capacity (I hope that is what it does).
"Math not being my thing, and I am not great with the metric system, I am thinking this might take me 15-18 miles as a reserve." In the real world you can consider a liter about a quart ( a liter is 1000cc and if I remember a quart is 948cc). So your 1 1/2 quarts of fuel (3/8 gallon) at 45 mpg would get you as you surmised, about 17 more miles.
That's a lot of math - I think I need a nap now.
Versys 650 is a Great Bike
I have a 2009 I bought in 2016. It is my reliable Japanese bike that I can count on. When one owns a non-Japanese bike, it is a necessity to also ride something that will not need as many repairs.
By the way, I registered almost 4 years ago, however the password reset does not work - no e mail sent to reestablish account. Tried several times.
Forced to use my wife's email address to get to this point.
Lou
:welcome:aboard and my apologies if you had problem on Log In. Please PM any super mod if you have further problem.
Enjoy your ride and be safe.
:welcome:
Understand on the back up bike. I keep toying with the idea to pick up an Aprilia Futura just for grins. Or maybe an old Water Buffalo...
Request change back to Lammy1000
Succeeded in logging in today!!
Consider yourselves lucky. My 2018 V1K will go 140 miles before the gas gauge drops a single bar. The remaining 4 bars drop off at about 25 miles each, so by the time I get to about 240ish miles, the gauge and tank match (both close to zero!).
On my '15 I loose the first bar at about 60-90 miles, depending on how bad(good?) I'm flogging it.
I seem to have about two gallons left at the point that I go to a single bar, and about 1.5 left when it starts blinking.
All of the above are assuming reasonably level road.
I would like some sort of indication when one is down to about a half gallon but at least the above seems to be consistent.
Reactions: quexpress
Going from memory, my 2015 650 LT fuel gauge did exactly the same as SteveJ mentions above.
FWIW, I averaged about 68mpg and filed up around the 340 mpg mark.
All the best,
Dave
When I did an "endurance" run on my '15 V650 to test its range (PROBABLY back in '15), carrying a gallon in case I ran out, when it went from showing a RANGE of 50 kms, to ZERO, I rode for around another 100 kms, then filled-up anyway and it didn't take nearly the 22L the OWNERS MANUAL says it holds.
So, IMHO the gas-gauge is VERY pessimistic!
1 - 15 of 15 Posts
