1 - 4 of 4 Posts
I read through a previous post about this subject but I couldn't find exactly what I was looking for. Anyone know if an aftermarket (stiffer) spring kit will improve the front end stability when hitting bumps on a turn? I seem to get a "floppy" feeling in the front end when hit a bump on a turn. Tire pressure is correct and the dampner is set at the the stock setting.
Thanks.
The V's front fork is noted for not getting out of its own way very well in high deflection speed large displacement situations. "Skipping-out" (floppy) is the result. This is due to oil weight and oil-flow through the orifices in the valving of the fork.
I, this past season, did fork-seals and purchased both 5W and 10W fork oil. (Stock is 10W) Mixing the 2 weights 1/2 and 1/2 produces an approximate 7.5W. This has very much lessened "skip-out". I've not as yet taken the time to re-tweak the fork's sag and damping.
If there's a proper suspension shop in your area... they can do bench-testing at different settings, oil-levels, and oil weights to sort issues like "skipping-out".
Thanks for the advice. I'll check the sag and do the fork oil change. I actually did just that on my Sportster a few years back and was happy with the results.
1 - 4 of 4 Posts
