Having trouble getting front sprocket nut off. Dallasdon posted that it is removed counterclockwise. no success. Is there a chance it is left hand thread? Help
Yes, loosen counterclockwise with 26 mm socket. A 1-1/16" (26.9875 mm) 6 point socket also works. I guess you already flattened back the bent washer behind sprocket. It's supposed to be tightened to 92 ft-lbs, but a lot of force is needed to break its original bond. I blocked the rear wheel with a padded length of 1-1/2" (38 mm) X 2-7/8" (73 mm) wood stud across the swingarm, and cracked the nut loose with an extension pipe on 1/2" drive breaker bar... I don't need the extension pipe anymore, now that its already been removed and torqued back to 92 ft-lbs. You'll need a very powerful impact wrench to loosen it but if you do, leave it in neutral. Use a torque wrench to re-tighten.
Hi there... I had the hardest time ever!!! to remove this nut... what I did was use a 1" 1/16th" socket... grounded the end of the socket (where if you have a look is usually a tappered edge on the inside of the sprocket) was that it had 100% flat edge on the socket to make sure that it had full bite surface on the rather shallow nut durface.... and with the rear brake locked on, clamping the chain and with a large length bar (and I do have proper gear for all this via my late father's Service Station tools) counter clockwise still couldn't remove the socket... I spent some 2 hours trying to remove it and in the end I got my dremel and cut a slot into the cross section of the nut and used a chisel to gently stretch the nut until if finially came off... (I am a metal worker so this isn't new to me) what I did then was repaired the nut with welding the cut I had made and refiled the nut and replace it (looks good as new with a fresh coat of silver paint on it) - when I changed the sprocket and did what I wanted to do.. however I did re-order another nut @ some $22.00Au and will repalce the nut next time I'm working on that area again. The problem being that the nut itself doesn't have a very large surface face area for the socket to geniunely bite on to. After further enquiring on other bikes that this seems to be a problem as they do lock them on pretty hard... I was told that the Dealership had a special rachet tool for this job. Hope this is of some help... catchya Andreas...... errrr still no responce on a 2007/08 VERSYS dealership catalogue? anyone got the candy Lime version brochure> - thanks
I know what you mean, I was also unable to break mine free by hand with a breaker bar and 2 feet of pipe on the end. Fortunately my neighbor had a 3/4 drive impact wrench, nut came off in about 2 seconds flat. I don't think it was necessary to put it on that tight at the factory. LOL
