So, poking around under the front of my '11 Versys I found these two male bullet connectors, one female spade connector and one plastic plug with multiple connections. Does anyone know what they are for and is it okay that they just dangle there?
179608
No luck in the manual. There's actually very little maintenance info in there.
Maybe I need to bite the bullet and buy the factory service manual.
Most likely those are the accessory plugs. By adding a relay you can use them to power up heated grips and the optional fog/driving lights. Without the relay installed they would not have power to them. The relay powers them up when key is ON.
Brad
2015 650 Versys LT ABS
Most likely those are the accessory plugs. By adding a relay you can use them to power up heated grips and the optional fog/driving lights. Without the relay installed they would not have power to them. The relay powers them up when the key is ON.
Brad
Correct, and to the right there should be an open plug for the Relay, and voila all accessories are working!
