1 - 20 of 44 Posts
Just bought a 2018 300 and noticed front brake seems to "pulse" when I brake. Not sure how to describe it--grabs then eases off. It is not an ABS model. Dirty pads? Air in system? Need advice!
I agree with JT in GA. The front rotor and brake pads will need to be closely inspected for what I call the "Rings of Saturn" on the rotor. By that I mean grooves or visual discoloration that would indicate wear and uneven warpage from excessive heat. It could be brake pads that are worn down to the backer plate or rivets. The good news is if the front brake fluid reservoir is showing normal level in the sight glass and there is no leakage anywhere around the brake caliper replacing the front rotor and brake pads should be pretty straight forward. Pads are around $35 and rotor cost (UPDATED 9/19/2022 $315 on Partzilla = ridiculous and hopefully not needed) and once swapped out your front brake should be back to like new.
09 v650
rotors are crazy compared to cost of pads...pads are 35-60 dollars. disc monies is kinda insane,.., see pic of screen shot....I know there are other options for buying..Sometimes the whole wheel asssemply used can be less expensive then the new part for the wheel etc.. I digress
Font Rectangle Terrestrial plant Screenshot Parallel
easy fix like new pads
I fixed my front brake pulsing by replacing the front brake pads on my 650 with EBC double H sintered pads after researching a bit. I dont notice pulsing anymore. The idea is that at a stop we use the front brake to hold the bike and when hot the softer OEM type pads leave a residue on the rotor.
Try cleaning and sanding the rotors first and see if that works. Spin the wheel while sanding with emory paper. I use 400 grit or even 220 grit on squeaky rotors. If that works for the pulsing, the EBC double H sintered pads should limit the residue left on the rotor. Better grabbing power as well.
Vx300 14/43: Urban Assault Vehicle
The downside of drilled and pedal rotors, lots of machining-high cost. Kawasaki is pretty proud of their work.
I’d try to verify it actually is a damaged rotor. Sure sounds like it.
I’ve brought auto rotors into an auto parts store to have them turned down before. It wasn’t very expensive. Might be worth asking someone offering this service to have a look at it. See what they say? I’d try to avoid telling them it’s a $400+ rotor if possible. Might see that as a reason to charge extra.
I had no idea that the rotor is very expensive - your example is $431. I just looked up the rotor on Partzilla and it is $315. Either case that is ridiculous. I hope none of us ever need to replace the rotor. Kawasaki seems to over charge for any larger part but the small stuff is reasonably cheap. It is what it is.
I'm always digging in to find simple and inexpensive solutions.
On ebay right now 9/18/2022 10:20AM there is a front rotor off a Versys X300 2020 model and that is used but could be considered if a front rotor is needed and it has no bids and starting at $42.74.
LINK to the ebay rotor: 20 Kawasaki LE300 Versys X-300 Front Brake Rotor 29C | eBay
Reactions: JT in GA
09 v650
Imagine what BMW says thier parts are "worth".....We now enter the "Ridiculous zone"....
Coat Flash photography Tie Font Collar
also, commentary says:
Tie Coat Font Suit Collar
Discussion Starter · #12 ·
Thanks, Dave. I did some sanding and cleaning on the rotor. Also, used compressed air to blow out some crud around the pads, but no real change. There doesn't appear to be significant run out. I guess the next thing would be to take off the caliper and clean, scuff the pads, but I can't find a good video on how this is done. The pulsing seems to correspond to speed, the faster the speed when braking, the faster the frequency of the pulsing, like there's a rotor issue, but it is clean and not warped.
You've done all the right stuff. It is a mystery why the pulsing is persistent. Keep looking and you will find the issue. The sanding you did on the rotor should have changed the characteristics of the pulsing. Any difference ?
Reactions: JT in GA
2019 Kawasaki Versys 650 LT
@ron.davis
I couldn't find a 300x video but here's a 300 Ninja think it's the same should get you the info you need also a chap that does a simple bleeding of the system
Are you putting on new brake pads? do you know how to seat then to the rotor, break them in?
Discussion Starter · #17 ·
Not really. I will probably bleed the line next, but it seems like if air in line was the problem brake would be mushy not pulsating.
Discussion Starter · #18 ·
There's lots of wear left in the pads, in fact I called the previous owner and he said he generally avoids using front brakes on motorcycles, which I find incomprehensible! Anyway, I did some serious cleaning with 400 sandpaper and brake cleaner and amazed at how much easier the front wheel spins. Will test for pulsation tonight, and if it's still there will bleed and then replace pads. Talk wheel bearings scares me!
Growing up on dirt bikes, I generally avoided using the front brake until I started street riding. But he may just have not wanted to admit knowing about the problem without disclosing it to you. All the more reason to look beyond the obvious to make sure you have a safe machine.
Does the front still wear factory rubber? A likely time for rotor damage is mishandling the wheel when it’s removed from the bike. Factory rubber up front could indicate the wheel has not been removed. Also check the cotter pin. If the ends are fully wrapped around the axle nut, that would also point towards maybe the front wheel never being removed.
I’m not sure how to damage a rotor on the bike, short of major trauma. I’d strongly recommend close and thorough inspection of the front end. Not trying to scare you. Just make sure all is well so you have peace of mind. I’d be especially concerned if there is no indication the front wheel has been removed
Discussion Starter · #20 ·
Thanks, these are not the original rubber. It ha good quality tires with only 2k on them. I just bleed the brake line to eliminate that. Barring any improvement, I guess the next step is new pads.
1 - 20 of 44 Posts
