1 - 11 of 11 Posts
2015 versys. Does anyone know the front axel bolt size and thread specs. I want to get a tap to chase the threads in the fork housing.:|
axle size
Thanks again, actually I measured it again with caliper and it appears to be 20mm with 1.5mm per thread.
axle size
Thanks, I used a better caliper and the axle actually measures 20mm and the threads are 1.5 per meter. Thanks for the help and the suggestions.
As I suspected, it's M18 (18mm) x 1.5 (1.5mm per thread).
Front axle diameter is 20mm, so the end is threaded to M18 x 1.5... The threads' outer diameter are easy to measure with a caliper.
Thanks Invader and Fast Eddie for you help, I have got it figured out now. It is great to be able to ask questions and get feedback.
1 - 11 of 11 Posts
