1 - 5 of 5 Posts
You can use the front wheel from an EX650 ninja but NOT a zx6r or zx10r because they run 25mm axles. So they look the same but they wont work. Same witch versys 1000, it runs 25mm front axle so its a no go.
If your bike has an ABS ring, the non abs wheel is compatible as long as you swap the abs ring.
Make sure the wheel you buy has no dings, IMO they ding a little easely on these.
1 - 5 of 5 Posts
