1 - 10 of 10 Posts
Newb here.
Did the intro thing.
I just bought a 07 with very very low miles.
Checked the right hand motor mount for cracks..none.
I have read all the posts about cracking on the right hand side but the latest seem to be about 4 years old.
Has everyone here shimmed the right hand side ? was this a common issue or something that was really very rare?
Sure glad that I found this thread, I had no idea the mounts were a problem. My right side had a larger gap than the right. Shimmed both sides accordingly.
Now to search through some older threads to see if anything else is a common occurrence and check for same.
Just shimmed mine. Did not have stainless washers on hand so I used regular ones.
I will eventually replace with stainless.
I did both sides, right hand gap was bigger than left.
the gaps were much bigger than I imagined.
New to me bike...oil changed, brake fluid changed, coolant flushed, motor shimmed and chain cleaned and lubed !!
Now...I ride...yehaa !!
1 - 10 of 10 Posts
