The seals on my 2007 650 Versys have started to weep and need to be replaced. Does it use the same seals as the EX 650 Ninja? My supplier does not list an All Balls seal set for the Versys.
Before you replace the seals, try this trick. It's worked for me a couple of times over the years, including a few months ago when one of the fork seals on my Versys started weeping. You may not need new seals and a few minutes could save you a lot of time and the cost of new seals.
tried the clean out and only worked for a couple of hundred km before they leaked again... here is info i posted previously
btw the ninja650 in canada has a conventional fork where the versys has a upside down fork
41x54x11 is what a net search finds , using docs saying it's the same as a 05 zx600rr...
This Kawasaki 92049-0058 SEAL-OIL is used on these models and components:
2005 ZX600-N1 Ninja ZX-6RR FRONT FORK
2005 ZX636-C1 Ninja ZX-6R FRONT FORK
2006 VN900B6F Vulcan 900 Classic FRONT FORK (~JKAVN2B1 7A015508)
2006 VN900D6F Vulcan 900 Classic LT FRONT FORK (~JKAVN2D1 7A010827)
2006 ZX600N6F Ninja ZX-6RR FRONT FORK
2006 ZX636C6F Ninja ZX-6R FRONT FORK
2006 ZX636D6F Ninja ZX-6R FRONT FORK
2007 KLE650A7F CANADA ONLY FRONT FORK
2007 KLE650A7F Versys (European) FRONT FORK
2007 VN900B7F Vulcan 900 Classic FRONT FORK (JKAVN2B1 7A015509~)
2007 VN900B7F Vulcan 900 Classic FRONT FORK (~JKAVN2B1 7A015508)
2007 VN900C7F Vulcan 900 Custom FRONT FORK
2007 VN900C7F Vulcan 900 Custom (European) FRONT FORK
2007 VN900D7F Vulcan 900 Classic LT FRONT FORK (JKAVN2D1 7A010828~)
2007 VN900D7F Vulcan 900 Classic LT FRONT FORK (~JKAVN2D1 7A010827)
2007 ZX600P7F Ninja ZX-6R FRONT FORK
2007 ZX600P7F Ninja ZX-6R (European) FRONT FORK
2008 KLE650A8F Versys FRONT FORK
2008 KLE650A8F Versys (European) FRONT FORK
2008 VN900B8F Vulcan 900 Classic FRONT FORK (JKAVN2B1 7A015509~)
2008 VN900C8F Vulcan 900 Custom FRONT FORK
2008 VN900C8F Vulcan 900 Custom (European) FRONT FORK
2008 VN900D8F Vulcan 900 Classic LT FRONT FORK (JKAVN2D1 7A010828~)
2008 ZX600P8F Ninja ZX-6R FRONT FORK
2008 ZX600P8F Ninja ZX-6R (European) FRONT FORK
2008 ZX600P8FA Ninja ZX-6R FRONT FORK
2009 KLE650A9F Versys FRONT FORK
2009 KLE650A9F Versys (European) FRONT FORK
2009 VN900B9F Vulcan 900 Classic FRONT FORK (JKAVN2B1 7A015509~)
2009 VN900C9F Vulcan 900 Custom FRONT FORK
2009 VN900C9FA Vulcan 900 Custom FRONT FORK
2009 VN900C9FA Vulcan 900 Custom (European) FRONT FORK
2009 VN900D9F Vulcan 900 Classic LT FRONT FORK (JKAVN2D1 7A010828~)
2010 KLE650CAF Versys FRONT FORK
2010 VN900BAF Vulcan 900 Classic FRONT FORK (JKAVN2B1 7A015509~)
2010 VN900CAF Vulcan 900 Custom FRONT FORK
2010 VN900CAFA Vulcan 900 Custom FRONT FORK
2010 VN900DAF Vulcan 900 Classic LT FRONT FORK (JKAVN2D1 7A010828~)
2011 KLE650CBF Versys FRONT FORK
2011 VN900BBFA Vulcan 900 Classic FRONT FORK
2011 VN900CBF Vulcan 900 Custom FRONT FORK
2011 VN900CBFA Vulcan 900 Custom FRONT FORK
2011 VN900DBF Vulcan 900 Classic LT FRONT FORK
2012 KLE650CCF Versys FRONT FORK
2012 VN900BCF Vulcan 900 Classic FRONT FORK
2012 VN900BCFA Vulcan 900 Classic FRONT FORK
2012 VN900CCF Vulcan 900 Custom FRONT FORK
2012 VN900CCFA Vulcan 900 Custom FRONT FORK
2012 VN900DCF Vulcan 900 Classic LT FRONT FORK
2007 KLE650A7F Versys (Canada Only) FRONT FORK
2007 ZR1000B7F Z1000 FRONT FORK
2007 ZR1000B7F Z1000 (European) FRONT FORK
2008 ZR1000B8F Z1000 FRONT FORK
2008 ZR1000B8F Z1000 (European) FRONT FORK
2009 ZR1000B9F Z1000 (European) FRONT FORK
Thanks guys. I tried the film trick with that seal mate thingy when the forks started to leak down in Mexico and it worked all the way down to Peru. However, in between shipping it back to Canada and getting it back on the road this spring, they have started to leak again. Since we are planning to leave for Alaska in June, it seems a good idea to go with new seals, just to be safe. Thanks again for the info and advice.
All Balls 56-136 is the fork and dust seal kit for the Versys, 2 of each.
As a matter of fact I'm going to replace the fork seals an d bushings on my '14 with 60,000kms and I'm using All Balls kits 56-136 and 38-6090. Despite what others might say about OEM fork seals being the very best option, I've yet to have an All Balls set of seals fail me.
Despite what others might say about OEM fork seals being the very best option, I've yet to have an All Balls set of seals fail me.[/QUOTE]
Well; here's hoping your Balls don't fail you this time either.>:)
On my recent 'adventure' w/ fork seals on my '08 in AZ - the aftermarket seals leaked TOO. The mechanic suggested the OEM Kawi ones, which worked...! (This was around 60K miles.)
:thumb: - :thumb:
