cannot located any info in manual re frequency or weight to use...any help appreciated including advise on changing viscosity or remaining with factory specs....thanks guys
2018 300 Versys
2018 300 Versys
kris thanks so much can u tell us more about your updated suspension system from YSS...i.e install easy/hard? difference in ride etc? thx againthese are simple forks. you can use any viscosity. but higher viscosity will firm the forks up a little. I fitted YSS front springs with springs preload adjustment. they sent me 15W oil. i am not sure what an actual viscosity it is as there is no information anywhere. Kawaski uses SS8, which has around 36 viscosity (at 40C). it is similar to Motul 10W.
it is firmer. and you have spring preload. is it worthy the upgrade? i am not sure; it depends on your preferences. I also fitted the rear YSS shock which is very nice, as it has damping adjustment.kris thanks so much can u tell us more about your updated suspension system from YSS...i.e install easy/hard? difference in ride etc? thx again
