I hit a bit of lead pipe on the highway a while ago, it's damaged the front wheel. There is no air leak but it's a decent bend in it. Now ive had little luck on sourcing a 2nd hand replacement and I'm just wondering if I could just try and knock it back into alignment or is this asking long for trouble?
There is a local company to you that does this professionally. I would guess around $75-100 if you just bring them the wheel with no tire on it. Just look for wheel straightening, if that doesn't find you something local, call a tire shop and ask who they use.
You say it is not leaking air so I'd say they are going to be able to get it darn near perfect.
There is a local company to you that does this professionally. I would guess around $75-100 if you just bring them the wheel with no tire on it. Just look for wheel straightening, if that doesn't find you something local, call a tire shop and ask who they use....
:thumb: - :thumb:
Taking the wheel to a bike repair place on Friday, might be able to fix it. Otherwise there is a second hand er6n wheel with tyre witg disc brakes on ebay for sale. I assume it will fit the Versys?
Yes, it should....
