1 - 20 of 79 Posts
Discussion Starter #1 (Edited by Moderator)
Hope this helps some of the new members to the forum.
Even though I've had my bike (2016 LT) since September I haven't had the money to do the upgrades I've been reading about in this great forum. Some of the posts go back years and it's been fun to compare results of others and to decide what are musts for my needs. I'm finally able to do most of these all at the same time, and it's made a world of difference! We've many new forum members since I joined so I thought they may be interested. Don't flame me if you don't agree with my personal choices, but chime in if you have some other MUST Farkles.
The bargains
Seat Riser Block- One of our forum members Rawkstar320 makes these riser blocks to raise the front of the seat so you don't keep sliding into your tank, A MUST buy and the best $14.00 you can spend on your Versys. http://www.kawasakiversys.com/forums/23-sale/115985-riser-block-front-seat-lift-mod.html
Pro Grip Gel Grips- $10.30 on Amazon. Just right grips that aren't hard, and they seem to remove most of the tingles too. I don't really need the heated ones.
KAWASAKI LIME GREEN REFLECTIVE MOTORCYCLE RIM STRIPES -$13.00 Found these on eBay, they are pre curved and easy to put on. They really show up at night!
Expensive but worth it.
GIVI 4114 ST Windscreen- I've read just about every review I could find and there is not a one size works for all, but the GIVI wins my vote and a great value at $117.00. You can read more about my experience- http://www.kawasakiversys.com/forums/11-modifications-cosmetic/124593-givi-d4114st-windscreen.html
Motowerk footpeg lowering blocks- $50.00 It's all about comfort here and it helps to eliminate the fetal sportbike position that my old body now rebels with cramps, etc. Between these lowering blocks and the below risers, the riding position is really opened up.
Motowerk Handlebar Risers V650LT- $50.00 I got the 1.5" risers and probably would have been happy with the 1" model. Much more relaxed sitting, the stock reach tended to make me slouch.
Motowerk Mirror Extenders- $36.00 Wow, I can really see behind me now, instead of my shoulders. The folks in Japan must really have narrow shoulders.:grin2:
Install next week-
JT Sprockets 16 tooth Front Sprocket- $10.30 . Since I can't add a 7th gear to my bike, this will be next best thing. I've been buying JT Sprockets for numerous bikes over the years and been really happy with their longevity. Yes, I know this one doesn't have the rubber covering, and yes I have a big Air Compressor and 1/2" impact wrench. The Versys is not the only bike that has issues with loosening that nut!:wink2:
Really happy with the results so far, calling it dialed in for a while.
Where in North Idaho? We lived in Post Falls for 27 years. Our favorite motorcycle road was Hwy 12 from Lewiston over the Lolo Pass. We would frequently stay at the Lochsa Lodge. Great memories!
I've done all those also (except the peg lowering blocks). I did add highway pegs which takes care of that bit of discomfort.
A couple of others you might consider are a throttle lock, gear indicator, power plug, dash phone mounting, further seat modification (foam/gel), and a nice trunk. Plus a nice set of gravel type tires.
I could go on and on cause the mod bug never stops.
Just ordered these -- thanks! A little money for a lot of visibility!
Yep, I'll be doing the throttle lock, gear indicator, power plug, and a trunk in phase 2 :wink2:
Thanks, that's cheap enough, I think I can sneak that one in past my financial advisor (wife). I'll guess I'll need the relay too.
Yes for the V-650 you need the relay for the V-1000 you don't...
Bang for the $...?
About $2 for 12 washers, two longer bolts, plus a piece of scrap steel to raise the front of your seat.
WORKS on Gens 1, 2 and 3...!
Can we have a pic with the seat on, for reference? Thank you!
Yes. BTW - I have ridden my '08 about 70,000 miles w/ this mod; my '09 about 64,000 kms w/ it; and my '15 for 27,956 kms w/ it. NEVER had a sore 'butt', nor damaged any seats....
The bargains
Install next week-
+1 on the Motowerk Handlebar riser. Very comfortable.
Also, the seat block by rawkstar320 is a very nice piece, unfortunately, it did not work with my Sargent Seat . The seat base would not latch in place.
Do you know what the Noise Reduction Rating (NRR) is for these?
Thanks for posting this info! :thumb:
sorry no.... but I must have tried just about every ear plug available and these (or similar) are the only ones that are comfortable for hours and cut out the noise. I think I am unusual because one ear canal is smaller than the other and any other type of ear plug was great on the left but terrible on the right and either fell out or hurt like hell. I nearly had some custom jobs made but I lose stuff all the time and these are cheap and effective.
When you pull them out you have a perfect impression of your ear canal!
Well worth trying out for the money - and make sure you follow the instructions and pull the top of your ear up as you insert.... more important than you think.
1 - 20 of 79 Posts
