My Radiator Fan was stuck, so I worked it back and forth, and it spins freely,and I put 12 volts to the fan motor, and the fan runs fine ,but on the dash,the warning light does not light up with the key on...should it? I was riding in stop and go traffic on a hot day the other day and I think the fan should have come on...it did not :mad: So could someone tell me where the Fan Relay is located on my 09... I checked the Fan Fuse and it's ok...Thanks...Suggestions?:dgi:
Thank you...
Your posting of pages has been very helpful stlee29 .:thanx: I will investigate and let you know what I find...I'm having trouble getting the codes to display on the dash...I touch the diagnostic wire to ground quickly 5 times in 2 seconds but don't see anything happening on the dash...?
It won't display codes if none are memorized. Current codes are displayed by grounding it once (and keeping it grounded with ignition on). Code 14 would indicate a problem with the water temperature sensor circuit... Are you sure it got hot enough to activate the fan?
Water temperature sensor removal/installation, output voltage inspection and resistance inspection procedures are on pages 129 and 130.
Any progress on this? :feedback:
Tomorrow I am digging in too, my fan stopped working yesterday- it spins by hand, but it doesn't kick in- discovered this when the fluid started to boil, without the warning light coming on...
Fan is Working Again...
I took a chance and ordered a Coolant Temp Switch for $50 and installed it...and bingo...the fan works and cycles on and off perfectly now...also changed the fluid while I was in there...The sensor is really easy to change...Thanks guys for all your help...:goodluck:
