So for quiet sometime i knew I had a fan problem on my Versys 2010 but didn't care much since I rarely needed it. However the time has come to fix so i did some troubleshooting
1)The 15 Ohm fuse underneath the seat is OK
2) The fan removed from the motorbike and powered by another source/battery works OK
3) I used a multimeter to test the cable that gives power to the fan, right next to the left fairing. Initially the voltage was 0v, but as soon as the bike heated up it went straight to 12v...and then back to 0v when it cooled off, which means the ECU properly signals for the fan to turn on
With my limited understanding, everything seems to work OK...so why the fan does not turn on?:|
