1 - 3 of 3 Posts
Has anyone encountered a vibration noise coming from headlight area of fairing whilst the bike is simply ticking over?
If so any suggestions on alleviating the problem. Cheers
Welcome.. please introduce yourself in the members introductions area: Member Introductions - Kawasaki Versys Forum
your noise could be from plastic panels resonating or they are touching something.
you can try finding the problem panel by touching areaa of plastic with a finger till you feel the buzz or the noise goes away.
depending on the cause, you can fix it with bits of foam or cloth tape on the back of panel.
someone with more knowledge of the Mk3 Versys will be along shortly to give better advice on your model Versys.
1 - 3 of 3 Posts
