1 - 20 of 25 Posts
I am getting ready to order a replacement and was thinking something other than clear would be fun. However, I am uncertain if the shields with metallic coatings are clear from the inside. Shield needs to be usable day and night. Thanks.
PS> Helmet is HJC IS-MAX II.
Thanks!
Here in Australia any tinted face sheild is illegal to use at night.
that being said...
I have a Shark Vision R with a internal flip visor.
Standard internal visor a med tint... it was good... but I swapped it for a silver iridium and it is soooo much better. you can really feel the difference when down as your face doesnt get burnt from the sun. the med tint really did not protect that way.
So I ride with sunglasses and use the internal shield for extra protection as well.
My helmet has a built in visor as is. I was just looking for something other than clear to use if I could.
EDIT: I found my answer reading some reviews. I'll be getting the clear one.
my shild is tinted, sucks come night time but great in the day
...However, I am uncertain if the shields with metallic coatings are clear from the inside....
From a friend who had one of the "metallic" coated visors - expensive, and easily scratched!
I don't know if you do any riding under 40ish degrees but If you do I would suggest getting a pin-lock ready shield.
I have a light smoke, dark smoke, yellow and orange for my Shoei Neotec. I don't use either of the smoke ones any more but I like the yellow and orange when it's overcast.
I bought a mirror shield on ny first helmet. It scratched VERY easy, and the scratches in the mirror reflect light very oddly, to the point of possible distraction.
I now buy dark smoke shields for my motorcycle and ski goggles. They cost less, look cool, and don't scratch as easy(I can scratch a ski goggle very easy bashing through the trees).
I have now started buying helmets with a drop down visor. This gives me the tint, but don't need to swap shields at sunset.
I think you already have your answer but I too use an internal flip down shield. Scorpion EXO-T1200...my second flip down shield. I don't have the patience (did I use the correct one?) for changing and won't get caught out at night with a dark one...
Sunglasses under the helmet 1) limit my peripheral vision and 2)can be dangerous in a crash
From someone who has recently had/used one... +1 ^ Not only that, but they are far from clear. Mild tint. Enough so they are dangerous in the dark.
The wife used it for a bit, she said it made her feel like "speed racer" lol
Seconded. The metallics look awesome, but scratch super easy.
Pinloc is a internally replacable film that clip to the inside of the External visor.
It turns the visor into a double glazed visor which is designed to remove fogging.
What I have been told is...
Helmet Visors without Pinloc have coating on the inside to help reduce fogging.
Helmet Visors that are Pinloc do not have these coating ... so that you have to use Pinloc to get anti-fogging.
Pinloc films can be expensive.
I really love my internal visor. I upgraded it from a med tint to a silver iridium one and for the last year had no issues with it scratching or being dirty.
I would choose a helmet with an internal visor over one without.
Flick it nearly all the down or half way just to give me enough protection in a low sun so that I can still see the instruments.
The only thing that might annoy some is that there is a tiny bit of ghosting from using a mirrored internal shield from reflections that you see bouncing from the mirror into the visor... It does not bother me and I don't see them much now.
I have had this mirror shield on my AFX fx39 helmet for about 3 years now. It looks great, has held up well (one small scratch when I got careless) but it is too dark to use at night.
My preferred choice is my AFX fx41 or before that my HJC IS16 with drop down internal tinted visors. I commute a lot on shift work where one of the trips is often in the dark.
I use Shoei sliver mirror shield. It reflects uv and microwaves and your eyes just feel more relaxed IMMEDIATELY. The silver is a light tint so night driving is not bad.
And I just put a 100% uv tint strip someone suggested here, and now it is perfect. Always get the more expensive factory visors: the fit is the difference between ear rattling and (more) quiet. I just replaced mine, and it's like a new Shoei 1100 helmet.
:grin2:
Pinlock shields are awesome! I have owned several regular shields that say how awesome their anti fog coating is, but they are lacking personally....
Pinlock shields are different. A typical helmet shield is a few millimeters thick of solid plastic. A pinlock starts out like that, but then goes and installs a softer bendable sheet of plastic to the inside of the originall shield. There is a small gap between the outside visor and the added pinlock. This has the effect of keeping the warm air by your face seperated from the cold air outside the helmet(like a double pain window in a house).
When I pull the shield closed, and breath very heavy inside my helmet, it will fog around the perimeter, but stays clear where the pinlock is located.
1 - 20 of 25 Posts
