1 - 16 of 16 Posts
Only in Canada / Nobody Cares
Yes, try clicking active topics then log in, if invalid redirect appears, click back , you will notice "log out" is active.
I have contacted admin several times, I have windows 10 and windows 7 computers, Firefox, Chrome and Edge. All three operating systems and two computers get unresponsive script message when I try to quote, this could easily be a bad add on the site targeting my area. It has been implied that it is my two computers and operating systems.Started in July just after the new sign in password change.I have had a third person try from a different location, different IP address and same problem.
So I have a fix for Firefox users. First turn off / uncheck,Hardware acceleration
https://support.mozilla.org/en-US/kb/troubleshoot-extensions-themes-to-fix-problems
I tried changing the integer to 20 from 10 on dom.max_script_run_time this made almost no difference. What I found is when the window pops up script busy, just close the pop up, do not click on anything . This allows a quote in about 20 to 30 seconds
Administrator
Hey there
What page are you trying to log in from? I have tried from within a thread, and from the main page, and I cannot recreate this error you are getting.
Which browser are you using when you get this error? And what skin version of the site are you on?
Dayle
Hey there
Dayle
Ummm, no idea what a "skin version" even is.... I use Google Chrome to get to the Kawasaki Versys Forum, then click on the user name at the upper right of the screen, then type in my password and hit "enter". At that point, the forum header is at the top of the screen and the error message is displayed where the different forum topics usually are..
Google Chrome / almost impossible to Quote took screen shots
Hey there
Dayle
I can take a couple more screen shots and maybe this can be solved from your end.
Administrator
You can locate the skin changer at the bottom left of the page.
It is a drop down menu and should state the current skin you have active.
Mine is Kawasakiversys.com (Full-Light).
When you guys attempt this, have you cleared your browsers cache and cookies recently?
Give that a shot, and let us know if that helps out.
Richard.
Browser is FireFox latest update
Skin changer is full light, I still get a unresponsive script, either replying or quoting, I have unchecked hardware acceleration in FireFox, which allows me to post within 20 to 30 seconds, the faster way was to hit quick reply, go advanced then post about 6 seconds total.Every time I leave all cookies and cache cleared, I have tried other things like disabling script, problem is the top tool bar with bold, italiics, underline, etc. doesn't show, also the emoji don't load.
As to Chrome, impossible unless you are willing to wait 3 or 4 minutes and keep clicking on wait to unresponsive script, basically locks up the whole computer similar to a memory leak. Only way I can post using Chrome is Quick reply then go advanced so I can have a subject displayed.
I have said this many times before, this all started around the time of the password upgrade, and it is not just my computers (2 of them windows 7 and windows 10) I have had someone with a gaming computer try, different IP address , with the same results.
Administrator
Richard.
Hey there
Were you able to find the skin version you are using? See our above post for information on that.
Also try the cache and cookies clear. To do that on Chrome, navigate away from this site, then click the 3 dots icon to the right of the address bar, open Settings. Go to History on the left side, the button Clear Browsing Data will be on top. A new window will open with several options. The first four are the ones you want selected.
There is a thread that was started on this a while ago. We responded in that thread, and no one replied back. This usually means the issue is resolved. If it is still an issue, please don't hijack other member's support threads. Respond in the appropriate thread, here: http://www.kawasakiversys.com/forums/8-verticalscope-forum-support-help-kawasakiversys-com/114601-unresponsive-script-message.html.
This thread will be to help the OP with the login errors. If you are experiencing the login errors as well, please add the information specific to that issue in this thread.
Dayle
Administrator
Hey there,
I just disable the drag and drop plugin since it was causing script error messages. let me know if it solved the error message as well.
Lee
same skin - Kawasakiversys.com (Full-Light).
I noticed that if I make a mistake entering my password, and go to the " failed login" screen, that everything works normally from that point.
Problem Largely solved
Hey there,
Lee
Latest news: logging in using Chrome, went in and cleared cache and cookies from beginning of time
I have enabled "use hardware acceleration when available" Login is now normal, for Chrome, Mozilla I get invalid redirect , click back and I am in.
As to posting / quoting, go to unresponsive script thread as I don't want to get a second Hijacking Thread Complaint ( but problem is solved thank you)
Administrator
I'm glad to hear that the issue has been resolved for you.
Has anyone else been able to successfully dodge these issues?
If not, please clear your cache and cookies as mentions by onewizard.
Richard.
Login Error/Invalid Redirect/ Different operating systems
Rather than start a new thread, I thought to quote myself, as the problem was never fixed, and this was before I became a mod.
What I have found, and my work around, problems on windows 10 only exist on Mozilla, Chrome login is fine. Windows 7 problems exist on both Chrome and Mozilla
Mozilla , load the site, once loaded click either active topics or New Posts, wait until the adds load in the right side bar and also the last to load is on top. If you have saved your login info on your computer , once the top add loads, you can then log in.
If you get invalid user or password and you have used 1 of 5 tries, notice Forum Jump, click on that scroll down to active topics or who’s online, click GO, your login info will come up, click login
Chrome
Basically the same, click Active topics or New Posts, wait until the top add loads, then login.If using Chrome invalid redirect pops up; if you click arrow back, click active topics, you will notice you are already logged in.
I am posting this simply to help others, I have absolutely no patience to personally go at this again, and yes I have had others PM / email me of password login failure, shouldn't be and obviously the operating system has a bearing on this, however it didn't exist in January 2016.
1 - 16 of 16 Posts
