1 - 5 of 5 Posts
So riding home yesterday, enjoying my ride, minding my own bussiness.
Approaching a traffic light, the bike die, look down to see if I have accidentially triggered the kill switch or something, I see no lights, etc. on the dash.
Stopping the bike on the side of the road, i check the ignition, turn to off, then to on. Nothing...not even a light or any indication on the LCD.
I check all fuses, nothing popped. Took the cover off where the main fuse is situated, the one close the the regulator, see that it has blown.
Luckilly there is a spare, so fitted the spare, bike fires up, next moment i see smoke coming from the regulator, so kill bike as quick I can. Fuse popped again.
Took it to the shop this morning, they busy checking it out....
Any ideas??
my guess, water ingress in the regulator connector
fried connector on the regulator, may need a new wiring harness assuming the bike is still in warranty, otherwise some inventive soldering may get you going
if its a wiring harness it may take several weeks to get a new harness
some bikes have had new wiring harness's fitted under warranty in the UK
so it may also need a new regulator
and its possible you may have done some damage to the stator and rotor.
The bike is not under warrantee anymore, so reffering to your post, I am in for a hefty bill.
I had the regulator replaced by the agent on March 2009 when it failed after water found its way into the connector plug. The agent did a mod, where an generic regulator was fitted in stead of the original part. They had to make up a small harness that plugs into the original regulator connector, and then into the generic regulator.
When this happened yesterday, I took it back to that same agent, so they should know where the problem lies, if it is not with their wiring, and fix accordingly.
I hope the problem lies with their original installation (Mod) otherwise I might be in for a hefty bill.
:feedback:
Hi Bronx,
Somewhere along the circuit it is shorting. Like Healdem metioned, water ingress the mostly likely culprit.
Page 525 of the service manual.
Hope you don't have to pay a hefty bill....:mad:
Maybe good to put a piece of shrink tubing over the regulator connector after this repair to keep it watertight.
My suggestion - take apart EVERY electrical connection you can find and then fill the ends with dielectric grease and push them back together. That should keep any water out! :goodidea:
1 - 5 of 5 Posts
