1 - 4 of 4 Posts
Normally I'll go the "home grown" route when modding, but this time I'm glad I went with some pre-fabbed pieces.
In this case, I started off with a basic kit for installing a fuse block and two 12V outlets.
From Eastern Beaver (great stuff):
1. (1) Fusebox Lead, inline fuse - 18in
2. (1) Unfused Socket Lead - 24in
3. (1) Unfused Socket Lead - 60in
4. (2) Powerlet 12V Socket
From Fuzeblocks.com (also great stuff):
1. (1) FZ-1
This setup allows you to install one outlet under the seat and one in the dash with minimal effort. Routing the wires was easier than I thought it would be.Just follow the existing wire bundles. Easy. One thing I forgot was the posi-lock taps but I made do with what I had in the toolbox.
Pictures, pictures, pictures...
Here is where I tapped the license plate light for switched 12V. Very easy to get to.
Here is the overall view of the compartment. You can see the 12V outlet and where I stashed inline fuse for the lead from the battery (tucks in perfectly).
A shot of the 12V outlet in the dash.
And a shot from behind... :rolleyes:
Now what else can I add...?
Nice write up and pictures. I'm going to add a power outlet or two soon.
What are you planning on using the under seat outlet for?
That one will be constant 12V. Closer to the luggage, so I can leave my phone or whatever in there while parked. and the outlet is secure under the seat.
I got the idea from A2RON here on the board. Thanks, bro. Clever spot.
1 - 4 of 4 Posts
