1 - 20 of 26 Posts
Hi fellow V riders,
I'm a new V owner (and a newbie biker too) and glad this forum exists...I'll be using it a lot :thumb:
I have read a lot on here about chain lubing and the Dupont teflon multi-use seems to be very popular. Unfortunately I can't find it in Eastern Canada (New Brunswick - we don't have Lowes or Ace Hardware here that I'm aware of).
Anyone know how I could get this magical chemical? I've found a non-aerisol version on eBay but it would cost over $30 to ship it here...not gonna happen.
Any help would be appreciated. Happy riding!
they carry it at cycle gear stores but i did't see it on thier website www.cyclegear.com
Discussion Starter · #3 ·
No Cycle Gear stores here either (I don't live in the sticks...really). Shipping to Canada is $25.
Can't get it here in Canader. I wrote Dupont to ask. IIRC, you can get it in the US, but if you buy it online, because it's aeorsol, it has to go UPS, which means added expense.
Discussion Starter · #5 ·
Cool, thx Red. Any close alternatives that you're aware of. I guess I"ll check out my local cycle dealers. I want something that doesn't collect grime and doesn't spin off.
Go in on a group buy with your buddies up there in order to share the shipping costs. That or a run to the states to get some :)
Try this stuff available from Lee Valley: Boeshield T9
:thumb:
Hi fellow V riders,
Discussion Starter · #8 ·
That looks like good stuff Yarne...do you use it? A little pricey but should last a while.
he Boeshield website...
"For applications such as bicycle chains apply by drip or dipping, wipe off the excess, and allow to set at least 2 hours, preferably over night. Frequency of reapplication will depend on riding extent and conditions, as well as method of cleaning after use. Typically, road cyclists get over 300 miles (500Km) per application in good weather. In wet weather reduce that by half. For off road riding reduce distance by half again for reapplication."
Does not seem like it would stand up well enought for motorcycle use.
I contacted Dupont and their Canadian distributor is in Mississauga, ON.(suburb of Toronto). Their number is 905-602-6022. I called and they will sell only in cases of six. Their cost on a case is $59.29 plus tax. This is the Dupont Teflon Chain Lube. They also carry the multi use product but why buy it if you plan to lube your chain?
Discussion Starter · #11 ·
Thanks! Maybe I'll buy a case...I'll use it eventually. Did they say what the cost is to ship it within Canada?
I didn't ask but you can call and find out. Talk to Bruno. I figured I'd buy a case the next time I run down to Toronto.
According to Web Bike World, Dupont Multi-Use and Dupont Chain Saver are the same product.... Did the distributor say chain lube or chain saver? Could be different products.
Rub
True Value stores are listed as carrying the product - stateside at least.... I searched and found a True Value store in St. Andrews NB. You might want to give them a call to see if they carry it.
St. Andrews True Value Hardware
189 Water Street
ST ANDREWS, NB
E5B 1A9
506 529 3158
Rub
Dupont does make a Teflon Chain Saver product (see the attached link) but I don't know if it's available in a spray can. I also don't know if it's the same product in a different can. Rather than fuss about this topic I think the Multi Use Teflon spray is probably the way to go here. If you live in Canada just call the Canadian distributor at 905-602-6022 and they will answer all your questions.
http://www2.dupont.com/Products_and_Services/en_AU/products/safety_protection/teflon_lubs.html
It's the same product with a different label.
Rub
I had planned on using this product since it was available locally and was a dry wax type protectant similar in description to the Dupont stuff...however, you could be right, it may not stand up for motorcycle use. Besides, 500K is not a generous interval for lubing a chain. I'll see if I can get a group buy together with some riding buddies and order the Dupont 6 pack. Thanks for the heads up!
Discussion Starter · #18 ·
Thanks for the True Value tip Rub. Would be a nice day ride from here too :thumb:
Were you able to get any of the Dupont spray at the True Value in St. Andrews? I'd like to get my hands on some of this stuff as well, sounds like it works well.
Discussion Starter · #20 ·
I didn't try yet actually. I ended up picking up some stuff locally that the dealer suggested...but I'm not completely happy with it. I'm still interested in the Dupont stuff. I may be heading down to Atlanticade in St. Andrews so will check it out then.
1 - 20 of 26 Posts
