Does anyone know of a brake pedal which fits the Versys that has either dual heights or a flip-down higher step? For standing on the pegs the rear brake pedal needs to be a bit higher than when sitting. There's several versions available for BMW bikes like this from AltRider where there is an inner portion which is higher than the main part of the pedal. While seated you use the outer larger portion of the pedal for braking, and while standing you use the inner raised portion of the pedal.
http://www.altrider.com/index.php/product/detail/pid/1965/cid/6
