1 - 3 of 3 Posts
I just changed the spark plugs. I now notice a clicking/ticking/arcing sound coming from the ignition coil area. This could have been there before, but I am not sure. Any ideas?
The noise sounds kind of like a light clicking, very much like some sounds those electric bug zapper lights make. The clicking noise is not in sync with the firing of the coils/plugs that I can tell. I can't hear it at all when giving throttle.
I even took the air box back off, took the coils off again and applied some dielectric grease. Still have the noise.
The bike runs fine otherwise. I just rode it around.
Is this noise normal/does yours do it?. I very well could have had it before, just didn't notice.
11,500 miles & used same model plugs (old ones looked almost new!!!)
I also went ahead and changed the air filter. After reinstalling the coils the second time, I changed the oil and oil filter too(just fyi).
Plugs were tourqued to about 12.5 ft-lbs, cause that's as close as I could get with my 0-75 ft-lb torque wrench. I also applied a tad of High-Temp Anti-Seize compound to the threads of the plugs, and was very careful not to get any on the electrode ends. I can't think of anything else to say. Please help:)
TIA, Jeremy
You might be hearing your injectors. A light valve ticking would be more audible on a warmed up engine. Both normal noises... Try holding a hose to your hear, with the other end touching an injector or other component to pinpoint your specific noise source if you can.
good idea, thanks invader.
Indeed, it's my injectors.
Thanks a million, the tube works great! Beer on me if your ever in Houston.
1 - 3 of 3 Posts
