1 - 20 of 41 Posts
just have to have airbox modded
secondary throttle bodies removed
slip on exhaust and a Power commander
:feedback:
i will send in a messege to idividuals
you will have to type in the map urself
Will this help me get more mileage out of my Pilot Road 2 Tire. Right now stock the best I have gotten is 2650 miles before it is bald all over.:D
wow u must be on the track the whole time ,.... i get 7000 out of the dulop qualifiers
What's the airbox mod? Removed airbox rubber inlets?
I guess you mean secondary throttle plates removed.
Do those fuel corrections maintain a ratio of about 13.2:1 acrosss the rev range at WOT? How about at partial throttle? What elevation and ambient temperature was the dyno and fuel ratio run done at?
i think it is 1500 ft (north phx, az)
yes its real good for me and at cruise range i am runing about 13.9-14.1
#1 cut the front of box off
#2 remove 2nd throttle plates
#3 have a slip on exhaust
Could you post your .djm file? I would like to try it, but not sure I ant to type it all in!:)
`Hi skizzo81, I would like to know more, some photo's and a write up would be good. :thumb:
MPG is nice, but I'm more than willing to give up a bit of it for better low end smoothness and most of all more OOMPH across the rev range. I think my map (see PC map thread) causes me to to lose a few mpg but picks a lot of grunt! To each their own.
Discussion Starter #15
is this anuff ooomff
compare to ur dyno chart and the lean out in my map is only at the cruise range. my 100% throttle is set to max power. it wont let me up load map files are (.pvm files)
What type slip-on? I am certainly looking for more hp but don't want more noise than stock if I can help it?
Discussion Starter #17
i am using a scorpion. and as far as the noise it will keep ur (a s s) alive when a car starts merging into ur lane and u rev it up an then they move over. loud pipes save lives!
Discussion Starter #19
Superstitious I see.... ;)
not superstitous... people are too buzy jacking off while driving so when they try to merge in my lane i start bouncing off the rev limiter and they swerve the other way.... saved my life a couple times... these people are lucky i dont carry a gun, they would be d e d dead!
1 - 20 of 41 Posts
